Tension of two ropes given mass and angle
A 1400 kg steel beam is supported by two ropes at angles of 20 and 30 degrees from the vertical. The tension in the ropes can be calculated using the equations for the x and y components of forces, ensuring that the sum of forces in both directions equals zero. The correct approach involves resolving the tensions into their components and setting up equations based on the beam's weight and the angles. After calculations, it was determined that the tensions in the ropes are approximately T1 = 8955 N and T2 = 6125 N. The discussion emphasized the importance of correctly identifying the angles and the direction of the tension forces.
alexas
A 1400 kg steel beam is supported by two ropes.
Tx = mgsin(ANGLE) ?
Ty = mgcos(ANGLE) ??
g = 9.8?
Tension of one wire = [((Tx)^2) + ((Ty)^2)]^(1/2) ?
I wasn't too sure whether or not i should use the angle: 20 or 70.
So i did it both ways they were both wrong, but i did it both ways...
[((1400(9.8)sin(20))^2) + ((1400(9.8)cos(20))^2)]&(1/2)
And then i did:
[((1400(9.8)sin(70))^2) + ((1400(9.8)cos(70))^2)]&(1/2)
Am i approaching this problem correctly? I have a test Thursday and i feel pretty F***** right now. Any help would be appreciated.
Tx = mgsin(ANGLE) ?
g = 9.8?
And then i did:
I can't see your picture as yet.
But resolving angles is no sweat. You always want the component in the direction of the axes, and however your angle is defined - relative to the horizontal or the vertical - you want the angle function determined by your drawing. Side opposite is sine, and side adjacent is cosine.
As to your method I think you need to think about what you are doing.
Most importantly remember for statics that the ∑ F in the x are 0 and the ∑ F in the y are 0.
Merely take the components of your tensions in the x and they add to 0. Now the components in the Y are supporting the beam. so those components of tension must add to the weight.
∑ Ty = T1y + T2y = m*g
For the x ∑ Tx = 0 then T1x = - T2x
So the the total Ty should equal 13720N correct?
m*g
1400*9.8 = 13720N ??
How would i go about finding the tensions of the individual ropes?
I was thinking that:
13720(sin20)) = gives you the tension of rope 1 with an angle of 20 degrees, and 13720(sin30)) = gives you the tension of rope 2 with an angle of 30 degrees.
Am i approaching this correctly?
m*g
Am i going in the right direction?
If the angles are with the horizontal then yes, the sum of T1*Sin(20) and T2*Sin(30) will yield the m*g.
Now write an equation for the x components.
Then all you need to do is solve for T1 and T2 directly.
2 equations and 2 unknowns means the end of the voyage is in sight.
T1sin(20) + T2cos(30) = 0 for the x-components?
I'm a little confused on how to go further from here...
The angles i believe are with the vertical axis, they are in the picture as rope 1 being 20 degrees to the left of the vertical y-axis and rope 2, 30 degrees to the right of the vertical y axis.
Sorry I can't see your picture. I previously said if the angles were with the horizontal. So if they are with the vertical then simply swap sin and cos. Sin is the x components then and cos is vertical.
Got it. So ...
T1*Cos(20) and T2*Cos(30) = m*g.
And
T1*Sin(20) = -T2*Sin(30)
Shouldn't it be:
T1*Sin(20) - T2*Sin(30) = 0
then...
T1*Sin(20) = T2*Sin(30)
then i did...
T1 = [(T2*Sin(30))/(Sin(20))]
using...
T1*Cos(20) + T2*Cos(30) = m*g.
Replace T1, with what i found earlier and...
[(T2*Sin(30))/(Sin(20))]*Cos(20) + T2*Cos(30) = m*g.
Pull out T2...
T2([(Sin(30))/(Sin(20))]*[Cos(20)] + Cos(30)) = 13720 N
T2 = 13720 N / {([(Sin(30))/(Sin(20))]*[Cos(20)] + Cos(30))}
T2 = 6125.64 N ?I know its wrong, i am just not sure where i am messing up.
alexas said:
Shouldn't it be:
I think you are already anticipating the direction of the Tension.
It's certainly true that |T1*Sin(20)| - |T2*Sin(30)| = 0
But the x components are opposed and hence not interchangeable if you take their directionality into account as
T1*Sin(20) = T2*Sin(30) might imply.
Ultimately you are really only interested here in |T1| = |T2|*Sin30/Sin20 for solving for T1 and T2, so I suppose it doesn't matter here.
I'm a little confused. Because i think what your saying is that i am doing it correctly? But when i solved out my answer for T2 the online system says I am wrong.
As for your calculation
I'd put it in numbers. It's easier for me to follow.
T1 = 1.462 T2
Then
1.462 T2 * Cos20 + T2 * Cos 30 = 1.374T2 + .866 T2 = 1400*9.8 = 13720
T2 = 6125 (Which is what you got.)
T1 = 1.462*6125 = 8955
Yes it looks like you are ok. Maybe you need to reverse the values for T1 and T2 in the answering system?
I'm an idiot. I was putting the T2 answer in the T1 box. LOLLL
I really appreciate your help. Thank You.
Sure.
Cheers.
