Engineering Test rig calculations - motor requirements
The discussion focuses on designing a tire test rig for measuring parameters like camber and slip angle, specifically for RC car tires. Key considerations include calculating the torque required by the motor to overcome the force from the rolling road, which will be simulated using a belt sander. Participants suggest using a lever arm to measure the torque by hanging weights until the wheel slips, applying the formula Torque = Force x Distance. Additionally, power can be calculated using Power = Torque x Angular Velocity, with angular velocity derived from the belt sander's speed and the wheel's circumference. The design should also allow for adjusting the pressure exerted by the wheel on the sander to ensure accurate measurements.
Ziv7
I'm designing a tyre test rig for a university project to measure camber, slip angle etc.
An example of a test rig - http://www.ika.rwth-aachen.de/forschung/veroeffentlichung/1999/30.06.-02.07/im173g.gif
Although my test rig will be for an RC car tyres, so not quite the same size...
The tyre will be connected to a motor which will induce deceleration (as a generator) or acceleration and I'm trying to figure out how I would be able to work out or what parameters I would need to determine the torque required by the motor.
My idea is that the motor will need to overcome the force induced by the rolling road (in this experiment it will be a belt sander)
Any kind of feedback or help will be appreciated!
I think you will have to experiment. eg fix a wheel to a lever arm and hang weights off the arm until the wheel slips. Torque = force times distance etc.
For the power...
Power = torque * angular velocity
You can work out the angular velocity of the wheel if you know the speed of the belt sander and the wheel circumference.
Should give a reasonable starting point I would think. Perhaps double up the figures for power and torque to give some flexibility?
Expect to wear out a few tyres!
The rig will need to be able to adjust the pressure the wheel puts on the sander. Ditto during your lever arm experiment to measure the likely torque.
