- 19,790
- 10,745
vela said:It still renders very slowly in IE8 because of the conditional.
oddly the emulation doesn't break IE9 now. the conditionals are off.
That's why I suggested ditching the inline configuration. The combination of inline configuration and IE7 emulation was breaking MathJax on IE9. Now that the pages load the configuration from a file, IE9 works in emulation mode.Greg Bernhardt said:oddly the emulation doesn't break IE9 now. the conditionals are off.
vela said:That's why I suggested ditching the inline configuration. The combination of inline configuration and IE7 emulation was breaking MathJax on IE9. Now that the pages load the configuration from a file, IE9 works in emulation mode.
Greg Bernhardt said:I might be mistaken but I thought the scripts were on a 24h cache.
MathJax no longer loads a default configuration file; you must specify such files explicitly. This page seems to use the older default config/MathJax.js file, and so needs to be updated. This is explained further at
http://www.mathjax.org/help/configuration
Anything in Opera logs?
[2011-05-24 23:31:18] JavaScript - http://cdn.mathjax.org/mathjax/latest/jax/element/mml/jax.js
Linked script not loaded
[2011-05-24 23:31:18] JavaScript - http://cdn.mathjax.org/mathjax/latest/jax/input/TeX/jax.js
[2011-05-24 23:31:49] CSS - [PLAIN][PLAIN][PLAIN][PLAIN][PLAIN][PLAIN][PLAIN][PLAIN]https://www.physicsforums.com/search.php?searchid=2702324[/PLAIN] [/URL][/URL][/URL][/URL][/URL][/URL][/URL]
Inlined stylesheet
-webkit-box-shadow is an unknown property
Line 1:
pace: nowrap; float: none; box-shadow: 5px 5px 15px #AAAAAA; -webkit-box-shadow:
Inlined stylesheet
-moz-box-shadow is an unknown property
Line 1:
5px 5px 15px #AAAAAA; -webkit-box-shadow: 5px 5px 15px #AAAAAA; -moz-box-shadow:
Inlined stylesheet
-khtml-box-shadow is an unknown property
Line 1:
5px 5px 15px #AAAAAA; -moz-box-shadow: 5px 5px 15px #AAAAAA; -khtml-box-shadow:
Inlined stylesheet
Declaration syntax error
Line 1:
geTransform.Microsoft.dropshadow(OffX=2, OffY=2, Color='gray', Positive='true')}
Inlined stylesheet
Line 2:
ng: 0; margin: 0; background-color: white; opacity: 0; filter: alpha(opacity=0)}
Inlined stylesheet
-webkit-border-radius is an unknown property
Line 1:
: nowrap; float: none; z-index: 201; border-radius: 15px; -webkit-border-radius:
Inlined stylesheet
-moz-border-radius is an unknown property
Line 1:
ndex: 201; border-radius: 15px; -webkit-border-radius: 15px; -moz-border-radius:
Inlined stylesheet
-khtml-border-radius is an unknown property
Line 1:
px; -webkit-border-radius: 15px; -moz-border-radius: 15px; -khtml-border-radius:
Inlined stylesheet
Line 1:
html-border-radius: 15px; box-shadow: 0px 10px 20px #808080; -webkit-box-shadow:
Inlined stylesheet
Line 1:
x 10px 20px #808080; -webkit-box-shadow: 0px 10px 20px #808080; -moz-box-shadow:
Inlined stylesheet
Line 1:
px 10px 20px #808080; -moz-box-shadow: 0px 10px 20px #808080; -khtml-box-shadow:
Inlined stylesheet
Line 1:
Inlined stylesheet
Line 2:
loat: none; z-index: 201; box-shadow: 0px 10px 20px #808080; -webkit-box-shadow:
Inlined stylesheet
Line 2:
Inlined stylesheet
Line 2:
Inlined stylesheet
Line 2:
http://www.mathjax.org/docs/1.1/tex.html#supported-latex-commandsJimmy Snyder said:Sorry, I don't know what is supposed to work and what isn't. \copyright doesn't work.
micromass said:Hmm, something annoying: I often make a post, then I edit the post. But after I edited the post, the LaTeX won't run. So I have to click refresh for the LaTeX to show up. It's no biggie, but I just wanted to let this know. (I'm on firefox, by the way)
Borek said:LOL, that would mean old problems with preview are still here![]()
Greg Bernhardt said:hmmm I can't reproduce this problem on FF 4.0.1
vela said:Do you have an add-on installed that might be causing the problem?
I see the same behavior with Safari. MathJax runs when the browser says it's done processing the page. Apparently, saving the edited post doesn't cause the browser to send this signal, which makes sense since if you have a script that runs when the page finishes loading, you probably don't want it to run again if you modify just a small piece of the page. So the text of the edited post doesn't get processed.micromass said:The weird thing is that the same problem also occurs on IE. So I don't think add-ons will be the problem.
Also, if I edit the post, then only the LaTeX of the edited post doesn't work. All other LaTeX formulas work fine...
vela said:I see the same behavior with Safari. MathJax runs when the browser says it's done processing the page. Apparently, saving the edited post doesn't cause the browser to send this signal, which makes sense since if you have a script that runs when the page finishes loading, you probably don't want it to run again if you modify just a small piece of the page. So the text of the edited post doesn't get processed.
EDIT: Firefox on the Mac acts the same way as well.
Borek said:Yes, that's the thing - refreshing works, quick edit doesn't.
So when it comes to preview we are back at square one.
I don't follow your logic. In fact, testing preview directly contradicts your conclusion.Borek said:LOL, that would mean old problems with preview are still here![]()
Greg Bernhardt said:There has never been preview for quick edit.
Fredrik said:I've had the same problem as Micromass since we made the move to MathJax. Every time I save an edit, I only see the source code. (Previews work fine. The problem is that when I view the post after saving the changes, I only see source code). A refresh solves the problem.
This isn't nearly as annoying or confusing as the old preview problem, which required a refresh after each preview. It also required me to explain it to someone else once a week.
OK, I just did some testing, and I don't have this problem at all. I guess I just remembered it wrong when I wrote the above. There is no problem if I preview before I save the changes. The only time I see the source code instead of an image is when I just click edit, change something, and then click save. Both FF4 and IE9 behave the same way.Fredrik said:Every time I save an edit, I only see the source code. (Previews work fine. The problem is that when I view the post after saving the changes, I only see source code). A refresh solves the problem.
I think it would be awesome if something like that could be implemented.vela said:Any thoughts on adding new delimiters for TeX code? MathJax supports multiple delimiters, so it won't break existing posts. Plus, it's faster typing something like $$ than the current tex and itex tags.
Daiquiri said:I can't see the "Sigma" icon for creating LaTex code, even in advanced text mode...
I am open to suggestions for additional delimiters.AlephZero said:The think that really bugs my typing is the foward slash in the closing tags and the backwards slash in LaTeX. [ \ tex ] (without the spaces!) as an alternative end tag would be nice.
Redbelly98 said:Hey, I'm glad to see that equations are automatically indented under the new implementation -- I'm pretty sure this was not the case before.
Fredrik said:I suggest
$f$ as an alternative to [itεx]f[/itεx]
$$f$$ as an alternative to [tεx]f[/tεx]
(I couldn't figure out how Borek did his magic so I just wrote ε instead of e to let you see what I wrote).
That first one might break a few old posts, but it still think it's the best option, since it's easy to type, and also what you actually type in a LaTeX document.
It not only breaks existing posts, but, as AlephZero noted, it makes it difficult to type a dollar sign when you want a dollar sign. Something like $$ and @@ would be better, or $$ and $$$.Fredrik said:That first one might break a few old posts, but it still think it's the best option, since it's easy to type, and also what you actually type in a LaTeX document.
Fredrik said:Yes, but this is a physics and math forum, not a forum for American accountants.I'm assuming that they can write something like \$3.50 instead of $3.50, and if that doesn't work, they can always write 3.50 USD.
(I'm not saying that I would find other options intolerable, only that I still like my suggestion best).
Greg Bernhardt said:I bet it would cause a lot of casual and new members a lot of grief at first. \$ is not intuitive :)
1. Sorry - no matches. Please try some different terms.
The following words are either very common, too long, or too short and were not included in your search : $$
Alt Gr is the key to the right of the space bar on my keyboard.Redbelly98 said:Fredrik, I'm not sure what this Gr key is. We normally use Shift, Ctrl, or Alt to change the character or function of other keys.
Good point.vela said:MathJax supports multiple pairs of delimiters, so it doesn't need to be one size fits all. You could have one set that's easy to type on US keyboards, and another set that's easy to type on non-US keyboards.
