The acceleration of a particle on a horizontal xy plane
The acceleration of a particle on a horizontal xy plane is defined as a=3ti + 4tj, with initial conditions for position and velocity provided. To find the position vector at t=4.00 s, one must integrate the acceleration to derive the velocity, then integrate the velocity to find the position, applying the initial conditions. The equations for position in terms of time are derived as dx = 1.5t^2 + vcos(θ)t + 20 and dy = 2t^2 + vsin(θ)t + 40, although introducing unnecessary variables complicates the solution. The correct approach involves using the constants of integration based on initial velocity values to solve for both components. Ultimately, the angle between the particle's direction of travel and the positive x-axis can be determined using the dot product method.
kara
The acceleration of a particle on a horizontal xy plane is given by a=3ti + 4tj, where a is in meters per second-squared and t is in sec. At t=0, the particle has the position vector r=(20.0m)i + (40.0m)j and the velocity vector
v=(5.00m/s)i +(2.00m/s)j. At t=4.00 s, what are its position vector in unit-vector notation and the angle between its direction of travel and the positive direction of the x axis?
I have no idea what to do at all https://www.physicsforums.com/images/smilies/surprised.gif
Find the general equations for position and velocity by integration and use the initial conditions.
"the angle between its direction of travel and the positive direction of the x axis"
For that you can apply the dot product.
so would i integrate a to find position and then velocity?
You integrate acceleration to find velovity, and then integrate velocity (after plugging in the initial condition) to find position.
alright so i got:
dx = 1.5t^2 + vcos0t + 20
dy = 2t^2 + vsin0t + 40
where the 0 is theta
kara said:
alright so i got:
Bringing in new variables (such as theta) without any need will just make the answer more complicated.
Here's an example on how to go about the problem:
\frac{dv_x}{dt} = 3t
v_x = \frac{3}{2}t^2 + C (C is the constant of integration)
Now put in the initial condition, the value for v_x when t = 0 and find the value for C. Similaraly find v_y. The process is the same for finding position.
You can be a bit more formal and use \vec{v}(t) = \int \vec{a}(t)dt + \vec{v}_{0}, i.e. \vec{r}(t) = \int \vec{v}(t)dt + \vec{r}_{0}, but basically that's the same thing Neutrino wrote.
