The Astonishing Heat Capacity of Snow: Explained
The discussion centers on understanding why 30,000 kg of snow at 0°C contains more heat energy than 1 mL of liquid water at 100°C. It emphasizes that temperature measures average thermal energy per molecule, not total thermal energy. The concept of heat capacity is crucial, as larger quantities of a substance at the same temperature can store more energy. To compare the two, one can use the heat of fusion and the formula dq = mcΔT to calculate the energy required to change the states of both the snow and the water. This analysis reveals that the sheer mass of snow significantly contributes to its total heat energy despite its lower temperature.
bandrews789
Explain how it is possible for a 30,000 kg of snow at 0 deg C to contain more heat energy than 1 mL of liquid water at 100 deg C. (Assume a pressure of one atmosphere.) I am unsure of where to start this? Help Is there a formula?
This is more of a conceptual thing: temperature is not thermal energy. Anything that is above absolute zero (zero Kelvins = -273 celcius) has thermal energy. Temperature is a measure of the average thermal energy per molecule in an object.
THink this way: what has more energy, a small cup of water at 100 C or a large barrel of water at 100 C? To put it another way, which one, the cup or barrel, needs more energy to get the water from 50 C to 100 C?
apply a phase diagram (and assume that heat capacity of the constituents of snow is somewhat identical to that of H20), apply the heat of fusion value to completely "freeze" the snow to find the heat energy of the process...bring the 1mL of water at 100C to the same state; find the corresponding heat energy (100C, apply dq=mcdT, bring it to 0C and apply the heat of fusion value).
Thank you for your assistance in this matter
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
