The conservation of mass in a region enclosing flow
The discussion focuses on the conservation of mass in fluid dynamics, specifically analyzing the equation involving the velocity vector and the unit normal vector. The term u · n represents the component of the fluid's velocity that is perpendicular to the surface area, which is crucial for calculating flow rates. On a solid surface, the value of u · n is zero, indicating no flow through the surface. The dot product helps determine the volumetric flow rate through the surface area, emphasizing the importance of understanding vector interactions in fluid mechanics. Overall, the conversation highlights the relationship between velocity components and mass conservation in fluid flow.
miniradman
In the equation representing the conservation of mass enclosing flow:
\int\rho \underline{u} \cdot \underline{\widetilde{n}} dA = 0
where:
\underline{u}= velocity vector
\underline{\widetilde{n}} = unit vector normal to surface A
a) what the meaning of the term \underline{u} \cdot \underline{\widetilde{n}}
b) what is the value of \underline{u} \cdot \underline{\widetilde{n}} on a solid surface
I find it hard to visualise a graphical representation of what a dot product actually is, however I know that it has something to do with how much one vector acts upon another. Using this fact, would the dot product of the normal vector and velocity vector give the velocity of fluid hitting the surface dA? I'm unsure about this.
part B, I have no idea what specific value could be derived from an expression like this one.
It's the component of the velocity perpendicular to the differential element of surface area dA. This times dA tells you the volumetric flow rate through dA (since the component of u parallel to dA does not result in any flow through dA).
What is the volumetric flow rate per unit area through a solid surface?
Chet
