The Fundamental Theorem of Calculus
thegoosegirl42
Evaluate the definite integral of the algebraic function. Use a graphing utility to verify your result.
Integral from [1 to 2] of (3/x^2 - 1)
The answer is 1/2
f(x)dx= F(b) - F(a)
I tried taking it to make it -x^-3 - 1x as the antiderivative but when I put 2 in and then 1 I don't get the answer.
Take the derivative to check your answer. Is it correct?
Gosh dang it I was going down in exponent when I should have been going up. The new derivative would be -3x^-1 -1x making the answer be -3.5+4 Thus the answer is .5. Thank you so much.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
