Calculating the Orientation of a Moving Rod Using Lorentz Transformations
To determine the orientation of a horizontal rod moving in the positive y-direction at velocity u, while observed from a frame S' moving in the positive x-direction at velocity v, the Lorentz transformation for length contraction is applied. The rod will appear slanted due to relativistic effects, but calculating the exact orientation requires understanding the equations for the world lines of the rod's endpoints. The initial approach involves using the Lorentz transformation to convert these world lines from the unprimed frame to the primed frame. While some participants have grasped the visual representation of the rod's orientation, the algebraic calculations remain challenging for others. Clarifying the algebraic steps is essential for solving the problem accurately.
TheLawR
1. Problem
Horizontal rod of length x traveling along the positive y-direction at velocity u. Determine the orientation of the rod in frame S', which is moving at velocity v in positive x-direction.
2. Homework Equations
Lorentz Transformation for length contraction, x' = \gamma(x-Vt)
3. The Attempt at a Solution
I have absolutely no idea how to approach this problem. I have a basic understanding of relativity, and how the transformations work, and I know that the rod will appear slanted, but I am not sure how to calculate in which direction.
Any help understanding this concept is greatly appreciated.
Try writing down the equations for the world lines of the endpoints of the rod in the unprimed frame. Then use the Lorentz transformation to find the world lines in the primed frame.
I was able to figure out how it would look like, and how it would be oriented. But we were offered extra credit for doing the algebra. I can't figure out how to work the algebra, or where to start.
