The page title could be Projectile Motion Problem: Calculating Work and Velocity
The discussion focuses on solving a projectile motion problem involving a 0.4 kg ball thrown upwards at 4.0 m/s from a height of 1.5 m. The total work done on the ball during acceleration is calculated to be 3.2 J, indicating positive work. The maximum height reached by the ball, neglecting air resistance, is approximately 2.32 m. The final speed of the ball upon returning to the original height is expected to be 4.0 m/s, but due to air resistance, it is found to be 3.6 m/s, leading to the calculation of work done by air resistance.
  • Understanding of Newton's laws of motion
  • Familiarity with kinetic and potential energy concepts
  • Proficiency in using kinematic equations
  • Knowledge of work-energy principle
  • Learn about the work-energy theorem in detail
  • Study the effects of air resistance on projectile motion
  • Explore advanced kinematic equations for vertical motion
  • Investigate energy conservation in projectile motion scenarios
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of projectile motion and energy conservation.
bphysics
There are four different components to this problem. Each component is short -- so don't worry.
a. Suppose you throw a 0.4 kg ball straight upwards from a height of 1.5 m, at a speed of 4.0 m/sec. How much work have you done on the ball by accelerating it from rest to 4.0 m/s. Is this work positive or negative?
b. How high do you expect the ball to get above the ground, if there is no air resistance?
c. At what speed do you expect the ball in #5 to be going when it comes back to the height at which you threw it (1.5 m)?
d. When the ball comes back down to 1.5 m, you find that it is moving at 3.6 m/sec. You correctly surmise that you can't neglect air resistance here. How much work has "air resistance" done on the ball?
x = x0 + voxt + (1/2)(axt2
v2x = v20x + 2ax (x - x0)
vx = vox + axt
WTOT = K2 - K1
a. WTOT = K2 - K1
(1/2)(m)(v2) = K
(1/2)(0.4)(4.0) = 3.2 J = K2.
K1 = 0 (initial velocity is zero)
WTOT = 3.2 J
b. vx = vox + axt
0 = (4.0) + (-9.8)(t)
-4.0 = (-9.8)(t)
-4.0 / -9.8 = t = .408
My thinking here is that when the ball reaches its maximum height, the velocity is zero.
x = 1.5 + (4.0)(.408) + (1/2)(-9.8)(.408)2
x = 2.3163
c. I'm pretty sure this is just plain wrong. Not sure why, but I have that feeling.
1.5 = 2.3163 + 0 + (1/2)(9.8)(t2)
t = .408 (time to go up that distance is the same as the time to go down??)
vx = vox + axt
vx = 0 + (9.8)(.408)2 = 1.63 m/s
d. I know I've screwed up already before. If the ball is moving at 3.6 m/s when it is coming back down WITH air resistance, that's already a bad sign.
vx = vox + axt
You shouldn't have squared the time there. Intuition would also tell you it will come back down at 4ms at that point-1
(a) and (b) look good. And as Jiacao said, don't square the 0.408 s for part (c), and you'll be in good shape there.
FYI, for both (b) and (c) you could have used
v2 = v02 + 2a(x - x0)​
Then you don't need t.
  • · Replies 38 ·
