The relationship between electric potential and field.
The discussion centers on the relationship between electric potential and electric field, particularly in two scenarios involving electrons distributed around a circle. In both cases, the electric potential at the center is calculated to be the same, despite differing configurations of the electrons. The confusion arises from the fact that while the potentials are equal, the electric fields differ due to their dependence on the gradient of the potential. It is emphasized that the electric field is related to how the potential changes in the surrounding area, not just its value at a single point. Understanding this distinction is crucial for grasping the concepts of electric potential and field dynamics.
Yumrey
There are 12 electrons spread on the circumference of a circle with radius R evenly. What's the electric potential at the centre? Then the electrons are concentrated on the upper half of the circle, spread evenly. What's the electric potential at the centre now?
Since electric potential is a scalar, the potential due to one electron is V=kq/R. By superposition principle, the potential due to all the electrons is simply 12kq/R=12V. Both situations have the same potentials.
What confuses me is that the electric fields in both situations are indeed different. In the first case, the field is simply zero because they all cancel at that point, while it's nonzero in the second case. But electric field is the negative gradient of the electric potential, then how come the same potentials result in different fields?
The field is related to the gradient. The same numerical value at a point may not have the same gradient.
Gradient is like a two or three dimensional slope.
Two functions can have the same value at a point but have different slopes.
Because the field is proportional to the gradient of the potential and not the potential. Also in one dimension you can have functions which take the same value in a point but have different derivatives.
To expand on that, the field depends on how the potential varies in a neighbourhood of a point, not on the value in the point only.
Likes Dr. Courtney
But then how should I differentiate the two Vs(which have the exact same expression) such that they'll yield different electric fields?
Think of potential like the height of the ground at a point. If the ground is flat, a ball won't roll. If the potential is flat, a charge won't move because there is no net electric force.
But if the ground is sloped, the ball will roll. If the potential is sloped, a charge will accelerate, because there is a net electric force.
Likes Yumrey
Read my last post before this one. If you only know the function value in a single point you cannot take the derivative.
Likes Yumrey
