Calculating Force: The Physics Behind a Rifle's Shot Speed and Barrel Length
  • Thread starter Thread starter atse1900
To calculate the force exerted on a bullet in a rifle, the initial speed of 320 m/s and barrel length of 0.82 m are used. The acceleration is determined to be approximately 62,439 m/s². Multiplying this acceleration by the bullet's mass of 0.005 kg yields a force of about 312 N. The discrepancy with the book's answer of 310 N may be due to significant figures. Accurate calculations and attention to significant figures are crucial in physics problems.
atse1900
A 5.0 g bullet leaves the muzzle of a rifle with a speed of 320 m/s, What force (assumed constant) is exerted on the bullet while it is traveling down the .82 m long barrel of the rifle?
This is what I have so far. : [.
(320)^2/(2*.82)=t
320/t=a
a= 62439
62439*.005
=312
The back of the book is 310. What did I do wrong?
I got what you got.
probably because the book gives answers in significant figures?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
