The Significance of the Mechanical Equivalent of Heat
The mechanical equivalent of heat defines the relationship between mechanical work and thermal energy, specifically that 4.2 joules equals 1 calorie. This conversion factor is not merely a numerical value; it signifies the fundamental principle of energy conservation, illustrating that different forms of energy can be interconverted. The ability to convert mechanical energy into thermal energy is crucial for understanding thermodynamics. Historical experiments, such as Joule's in 1843, provided empirical evidence for this equivalence. Overall, the mechanical equivalent of heat has significant implications in both classical and quantum mechanics.
miss photon
we define mech equivalent of heat as the amount of work done in joules in order to provide 1 cal of energy.
4.2 J= 1 cal
is mech equiv of heat simply a conversion factor or does it have any other physical significance?
Science news on Phys.org
the Joule and the Calorie are both units of measures of energy, but defined differently, so with the necessary analysis (or experiment), they can be (and are) related by a conversion factor.
An example: If pushing an object against friction requires 4.2J, it will generate 1 cal of heat. Thermodynamics is basically the study of converting energy between heat and mechanical.
that doesn't answer my question, is there any physical significance of mechanical equivalent of heat?
The particular value is just a conversion factor, but the fact that you can "convert" mechanical energy to thermal energy at all is extremely significant. This led the way to the modern concept of energy conservation and the idea that while it takes various forms, all "energy" is equivalent. Joule performed a classic experiment in 1843 to demonstrate the equivalence of "heat" energy and mechanical work: http://en.wikipedia.org/wiki/Mechanical_equivalent_of_heat"
miss photon:
Yes, it have any other physical significance.
Because heat is just the mechanical energy of atoms or molecules there must be a way to derive 1 cal from 1 Joule.
In a gas there must be a simple way of doing that, if you define 1 cal in function of pressure of the gas.
In solids, I think you must apply QM.
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
