The tension in the cord in this system
The problem involves a system with two blocks, where one block is on top of another and connected by a cord. The scenario includes forces acting on the blocks, friction between them, and the need to analyze the tension in the cord and the normal forces involved. The subject area includes dynamics and forces, particularly focusing on Newton's laws of motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss drawing free-body diagrams for each block to derive equations for the forces acting on them. There are attempts to analyze the components of tension and normal forces, with some participants expressing confusion about the relationships between the forces and the blocks. Questions arise about the assumptions made regarding the motion of block B and the implications of the forces acting on it.
The discussion is ongoing, with participants providing guidance on maintaining algebraic expressions and emphasizing the importance of free-body diagrams. There is a focus on deriving equations from the diagrams, and some participants are exploring the relationships between the forces without reaching a consensus on the next steps.
Participants note the importance of considering all forces acting on the blocks and the implications of Newton's third law. There is mention of specific values, such as the weight of block B, but the discussion remains centered on the conceptual understanding rather than numerical solutions.
Blueberrymuffim
A force F is applied horizontally to a block A of mass mA =
0.600 kg so that it slides on the floor with acceleration g/3.
Block B of mass mB = 0.200 kg rests on top of A, but is kept
in place by a cord which is tied to the wall at 45.0°. The
coefficient of kinetic friction between the two blocks is μ1 =
0.500 and between block A and the floor is μ2 = 0.250.
(a) Draw a free-body diagram for each block.
(b) Find the tension in the cord.
(c) Find the normal force that block A exerts on block B.
(d) Find the normal force that the floor exerts on block A.
(e) Find the force F.
F=m.a fk = Mk*n
I tried to find the Tension by the components of the vector. Initially, I found that since the angle of the force is 45 degree, then I have an isosceles triangle for the components which each force will be the same in the component by in different direction which changes the sign (just assuming).
Then, I separate the forces of the Tension in components Fy and Fx acting in the block B.
Fy= S (force of the component y of tension) + n (normal force) - W (mass of B * gravity)
I assumed that Fy would be equal to zero because it is not moving in the vertical direction which means the sum of all the components of this net force will be equal to zero.
So, I decided to isolate S + n= 1.96.
So, S+n = weight.
n=1.96 N - S
Fx= fb (friction force) + S(force of the component x of tension).
Fx= Mk*n+S
Fx=0.5n - S
Fx = 0.5(1.96 - S) -S
Fx=0,98 - 0.5S - S
Fx = m.a by the given information we have Fx= 0.653N
S = -3.266 N
I am confused about the letter b. I guess I can find the normal force of each blocks after I found the Tension of the cord.
Have you tried (a) yet?
When you do that, you can derive equations from that to answer the other parts in order.
Blueberrymuffim said:
S + n= 1.96.
A very good habit to get into is keeping everything algebraic, only plugging in numbers at the very end. It has many advantages.
I thought we were dealing with block B here.
Yes, I did the free body diagram. It is attached here.
Honestly, I haven't used any equations on it yet. My initial thought was to think about Force net and tension and they are the sum of the forces acting in the system, right? Obviously, it also uses the second law of Newton F=ma, but I don't really see how to get on this step yet.
Can you be more specific on this, please? I've been trying to look both blocks and find things in common in a way that I may end with substitutions and I can find common variables.
Yes, we're dealing with block B here. Weight of B is 1.96N. and what you're quoting is my initial idea of components of force net which would be S+n-W. Since the only variable I have is the weight s+n = 196N
... which is stationary... so why the nonzero ma?
From your diagram for block B, you should be able to find (b) and (c) without reference to block A at all.
For block A, you don't seem to have shown any vertical force from B. Think about Newtons 3rd law for the force n1 .
I presume n2 is the force from the floor pushing A upwards. The 3rd law force acts on the floor (Earth).
You show the force from the gravity of Earth pulling A downwards. The 3rd law force acts on the Earth.
Edit: PS. Do you remember sin(45)=cos(45)
Edit2: PPS. You seem to use force symbols which do not appear on your diagrams (S, W, Fy ). IMO this is unhelpful. I think you can mark on all the forces you need and use only those in your equations.
