jeebs
- 314
- 5
Hi,
I have this problem about an object moving along a track due to a uniform gravitational field. It moves from being at rest in the higher position A (xA,yA) to the lower position B (xB,yB). There is no friction at all. What I am supposed to be doing is showing that the total time from A to B is given by:
t_t_o_t = \frac{1}{\sqrt{2g}}\int dt \sqrt{\frac{(dx/dt)^2 + (dy/dt)^2}{y}}
where the limits of the integral are given as between (xA,yA) and (xB,yB).
The limits I do not quite understand, because surely they should really be times rather than positions if we are integrating with respect to time?
Anyway, what I have attempted is this:
From Newton's equation of motion, v2 = u2 + 2as, if we set initial velocity u = 0, gravitational acceleration a = g and vertical displacement s = y, then we have an expression for the object's final velocity, v = \sqrt{2gy}.
Also, I said that the instantaneous velocity will be given by v_i = \sqrt{(dx/dt)^2 + (dy/dt)^2}.
Since these two things match the denominator and numerator in the integrand respectively, they must be important. Clearly vi/v = 0 at time t=0 and position A, and increases to vi/v = 1 at time t=ttot and position B.
This is where I start to hit trouble though. I'm not really sure what to make of these spatial limits and I can't see the way forward. One thing I have tried is to say that
(\sqrt{(dx/dt)^2 + (dy/dt)^2})dt = \sqrt{dt^2(dx/dt)^2 + dt^2(dy/dt)^2} = \sqrt{(dx)^2 + (dy)^2} = dy\sqrt{(dx/dy) + 1}
but when I proceed with the integral integrating with respect to y from there, I end up with a quantity that does not have dimensions of time.
Can anyone steer me in the right direction?
Many thanks to those who try.
