Can Relativity Account for the Age Difference in a Big Circle?
  • Thread starter jdavel
  • Tags
    Circle
In summary, the conversation discusses a new configuration of the twin paradox where the traveling twin goes in a big circle around a star instead of a straight trip. It is argued that this configuration should lay to rest the argument that special relativity cannot account for the age difference between the twins. It is also suggested to do a relativistic doppler calculation for an object moving in a big circle. However, it is pointed out that the twin at the center of the circle won't see the traveling twin's clock rate affected by the doppler effect. In another configuration, it is proposed to keep the traveler's deceleration and acceleration at 1g, but it is explained that this would not make the Earth twin the younger one as the age
jdavel
617
I haven't seen the twin problem configured this way before. But it seems to me it should lay to rest the argument that SR can't account for the age difference.
Instead of going from the Earth to the star and back, the traveler goes from the Earth in a big circle around the star and back. The star is the center of the circle and the Earth is a point on the circle. The traveler then experiences a continuous acceleration throughout his trip. If the star is 100LY from Earth and the traveler's speed is .99c then his acceleration (v^2/r) works out to about 8m/sec/sec. That's less than the 9.8m/sec/sec that his twin experiences staying on the earth! So, when he returns (2pi*100 years later), if he has aged any less than his twin, it can't be because of acceleration.
Now all you have to do is a relativistic doppler calculation for an object moving in a big circle. I haven't done it, but it shouldn't be hard. The distance between the twins is r*sin(theta/2) where theta is the angle at the star. So their relative speed is just 1/2*r*cos(theta/2), or about 50*cos(t/200), where t is in years. The total number of ticks on the traveler's clock should be an integral of his tick rate doppler adjusted for this speed.
The twin paradox ordinarily assumes the flat spacetime of SR--so although you can refer to one twin being "on Earth", the curvature of spacetime due to gravity is generally ignored. In any case, when people say that the twin paradox is explained by acceleration, no one says the magnitude of the acceleration determines the age difference--for example, in the ordinary twin paradox where the traveling twin moves out inertially, turns around, and comes back inertially, you can have the same acceleration in the turnaround but vary the length of time spent moving out and coming back and the age difference will change significantly.
The twin at the center won't see the traveling twin's clock rate affected by the doppler effect, because the distance isn't changing. The twin at the center will see the traveling twin's clock slowed down by the time dilation factor of [tex]\sqrt{1 - 0.99^2}[/tex], while the traveling twin will see the clock of the twin at the center sped up by the same amount.
JesseM,
"The twin at the center won't see the traveling twin's clock rate affected by the doppler effect..."
I didn't explain clearly enough. The star is at the center of the big circle; the Earth is on the circle. So neither twin sits at the center of the circle.
In the interem an even simpler configuration has occurred to me. You don't need the circle. Just do the whole thing the regular way (out to the star and back) but keep the traveler's deceleration and receleration (when he's turning around) right at 1g. Since the Earth twin experiences the 1g during the whole trip, if acceleration is the cause of the age difference, he should be the younger one. Right?
Incorrect.
You can see the correct calculations here
jdavel said:
JesseM,
My fault, you did explain that in your original post, I just got confused. In this case the doppler shift as seen on Earth will depend on the angle of the ship's motion relative to the axis between it and the Earth at that moment.
No, what I said previously still stands, the difference in ages is not a function of the magnitude of acceleration, it depends on the entire path. As an analogy, we know the shortest distance between two points in a plane is a straight line, which in any x-y coordinate system would mean a path of constant slope (where slope at a point on the path is delta-y/delta-x for an arbitrarily small interval around that point). So, if we have two points with a path of constant slope between them, and another path where the slope is constant for a while going out from the first point, then there's a change in slope, then it's constant for a while again until the path reaches the second point, we know this second path will have a greater length (the path will look sort of like one of those drinking straws with a bend in it). But is the difference in length between the straight-line path and the bent path just a function of the rate the slope was changing during the (brief) non-constant section? Of course not, the total length of the non-constant section may be very small, with almost all of the length of the bent path being made up of the two straight segments. The key is that each straight segment was not parallel to the straight line joining the two points, but was going off at a different angle.
Here's a great paper dealing specifically with the twins on a ring that appeared in AJP
http://www.elizabethheider.com/publications/circular%20twin%20paradox.pdf
djavel: "I haven't seen the twin problem configured this way before. But it seems to me it should lay to rest the argument that SR can't account for the age difference."
SR always accounts for the age difference - the issues arise in connection with whether nature works the way SR demands in order to arrive at the age difference, ...or whether the interpretations of different individuals are functionally equivalent.
Related to Can Relativity Account for the Age Difference in a Big Circle?
1. Who are the twins in a big circle?
The twins in a big circle are fictional characters created for a thought experiment or a hypothetical scenario in the field of science.
2. What is the purpose of the twins in a big circle thought experiment?
The purpose of the twins in a big circle thought experiment is to illustrate the concept of time dilation and the effects of relativity on time and space.
3. How does the twins in a big circle thought experiment work?
In the thought experiment, one twin stays on Earth while the other twin travels at high speed in a big circle and then returns to Earth. Due to the difference in velocity and the effects of relativity, the twin who traveled will age slower than the twin who stayed on Earth.
4. Is the twins in a big circle thought experiment possible in real life?
While the concept of time dilation is a proven phenomenon, the exact scenario of the twins in a big circle may not be possible in real life due to practical limitations. However, similar experiments have been conducted with atomic clocks in orbit, which have shown the effects of time dilation.
5. What can we learn from the twins in a big circle thought experiment?
The twins in a big circle thought experiment can help us understand the concept of time and space in relation to relativity and the effects of high velocity. It also highlights the importance of understanding and considering the effects of relativity in modern technologies such as GPS systems.
