The van der Waals Equation: What is the exact meaning of 'volume of gas'?
  • Thread starter Thread starter Kaushik
    Gas Van der waals
For real gases at high pressure, the measured volume often exceeds the calculated volume derived from the ideal gas equation. This discrepancy arises from the significant volume occupied by gas molecules themselves, which is not accounted for in the ideal gas model. The discussion emphasizes the importance of understanding "free volume," which refers to the space available for gas molecules to move, excluding the volume occupied by the molecules themselves. The van der Waals (vdW) equation clarifies this by incorporating a term that accounts for the volume occupied by the molecules, indicating that the measured volume includes both the free space and the volume of the molecules. The conversation highlights the need to differentiate between occupied volume and free volume, as well as the dynamic nature of molecular movement within a gas. References to PW Atkins' "Physical Chemistry" are suggested for further clarification on these concepts.
Kaushik
It is said that, for real gases at high pressure, the measured volume is higher than the calculated volume.
My perception of the volume of the gas, as of now, is the following: The free space available for the gas to move. It excludes the volume of the molecules. So on increasing the pressure, the volume of the molecules becomes significant. So the measured volume should be less than the calculated volume. (Calculated volume is the volume obtained from the ideal gas equation).
I reckon that the confusion of mine arose due to the misconception of "volume". Please correct me :)
Chemistry news on Phys.org
If you simply look at the vdW equation you can see there is a factor ##V - nb##. This means V is the occupied volume including the volume of the molecules themselves.
Your perception seems right to me. The conclusion not: ideal gas equation has 'free volume'; occupied (= measured) volume is larger by ##nb## .
A good reference is PW Atkins: Physical chemistry. He has a whole chapter on this.
Likes Kaushik
What do you mean by 'free volume'? Do you mean the volume of the container - the volume of molecules?
It says that instead of moving in volume V, it is restricted to move in V-nb. So the measured volume is V - nb?
No: you measure the volume including the volume of the molecules. They are in there !
Correct: the volume available for the molecules to move around in is the container volume minus the volume occupied by the molecules themselves. Of course the 'no go' volume is not a fixed (in time) 3D area, but an average fraction of the container volume where they can't go because of other molecules being there.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
