(Theoretical) Repurposing of electric elevator motor
Repurposing an electric elevator motor for a scavenged electric vehicle is feasible, provided the motor has sufficient horsepower, ideally between 5hp to 200hp, to move a 7-ton vehicle. The character can also scavenge a gear reduction system to enhance performance. While the motor's original design may differ from its new application, the principle of using electric power remains valid. The speed of the vehicle will depend on the motor's horsepower, with lower-end motors resulting in slower movement. Overall, the concept is plausible within the outlined restrictions and can be realistically integrated into the narrative.
Benson2104
Greetings,
I am writing a Fan Fiction for someone and had a technical question. I like to do as much research as possible and have my "work" be as accurate/realistic as possible, so here I am. I know this might not be the place to ask it, but if you know of any place more suitable I wouldn't mind you pointing me in the right direction =)
Okay, getting down to it.
I need one of my characters to build an electric vehicle, but he/she is under some restrictions.
1) The setting does not allow for store purchases, everything has to be scavenged.
2) Anything used in the construction needs to have existed pre-1950.
What I was thinking was repurposing a scavenged electric elevator motor from a building (Do not worry about how they will remove/transport it) to drive what will be roughly a 7 tonne vehicle, excluding load and the motor itself. Luckily, the setting provides convenient (and very strong) power sources. I know the motor in question doesn't work on the principle I'm proposing, but it's the only thing I can think of with more or less the power required for the size of the vehicle I have in mind and also meets with the restrictions. Could this be done? Keeping in mind I only have basic knowledge of electrical engineering (10 minutes on Wikipedia =P): How? What tools and/or additional components would be needed to get it done?
Additional notes:
1) I won't be able to read / reply to any inquiries for a few days, don't have internet at home.
2) No, this is not how I write when I'm serious =P
3) I usually ask questions like this, then figure it out a while later myself, look back and think: That was a stupid question. Here's hoping its not one of those cases.
Working under the assumption you have access to electricity, and assuming the character "scavenges" the gear reduction while he is "scavenging" the electric motor there is technically no reason a 5hp to 200hp electric motor could not move a 7 ton vehicle, though you aren't going to get it moving very fast with motors from the low end of the range. A 35hp tractor can move some incredible loads, and the source of the horsepower (electric vs ICE) is unimportant.
So, you can write about the elevator motor w/o fear of improbability, just make sure the HP and the speed are "reasonable".
Fish
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
