Thermal Energy in 1 cubic meter of air at room temperature
The discussion revolves around calculating the thermal energy in one cubic meter of air at room temperature, estimated at 151,815 Joules based on the kinetic energy of air molecules. The density of air is noted to be approximately 1.2 kg/m³, leading to a gravitational potential energy calculation of 1,176 Joules for a mass falling 100 meters. It is concluded that thermal energy significantly exceeds gravitational energy in this scenario. The importance of unit tracking in calculations is emphasized throughout the discussion. Overall, the calculations confirm that thermal energy in air at room temperature is much greater than the gravitational energy from a fall of 100 meters.
Bgerst103
How much thermal energy was in 1 cubic meter of air at room temperature. Give your answer in Joules.
How much kinetic energy does one cubic meter of air have if it were to hit the ground after falling 100 m? Give your answer in Joules.
Which has more energy? Gravitational energy or thermal energy?
I'm not really sure how to calculate thermal energy of air. Room temperature is 25C I believe.
Perhaps think about the kinetic energy of a single gas molecule (=3/2 kT).
So, there are about 2.5 x 10^25 molecules in 1m3 of air. K is 1.381 x 10^-23. I've decided to use 293.15 K as my temperature. So the kinetic energy of one molecule is 6.0726 x 10^-21. So do I multiply this by 2.5 x 10^25? That would come out to 151815. If this is right how would I turn this into joules?
If that's the right number of molecules (I haven't checked) then that would be the energy in Joules.
Thermal energy in one cubic meter of air
2/3kT
So, there are about 2.5 x 10^25 molecules in 1m3 of air. K is 1.381 x 10^-23. I've decided to use 293.15 K as my temperature. The kinetic energy of one molecule is 6.0726 x 10^-21. So, I multiplied by 2.5 x 10^25 would come out to 151815 J, is this thermal energy? How do i calculate the kinetic energy after falling 100m? I'm assuming i just compare the two to answer the third question.
I think your calculation of the thermal energy is correct. Can you calculate the mass of 1 m^3 of air? Do you know how to calculate the gravitational potential energy gained when a mass m falls a distance h under the influence of gravity?
That's already in Joules (You would know that if you kept better track of units. That's a very important point that for some reason most student blow off as unimportant or trivial. Don't make that mistake. Instead of "K is 1.381 x 10^-23" say "kB = 1.381 x 10-23 J/K" Note all the changes I've made to your statement. They were all intentional). I didn't check your math, it but seems to be in the right ball park.
Likes 1 person
The density of air at room temp is about 1.2 kg/m3 so mass would be M=DV so I guess the mass is just 1.2 as well? Gravitional potential energy is just PE=mgh correct? So then, 1.2(9.8)(100)=1176 meaning thermal energy is much greater than gravitational.
I think that's correct.
