Thermal-expansion coefficients, convection as function of T
The discussion revolves around the relationship between the volume-expansion coefficient (beta) and the linear-expansion coefficient (alpha) in isotropic solids, as well as the behavior of heat transfer by convection as temperature differences increase. Participants explore definitions, textbook references, and the implications of different formulations of these coefficients.
  • Some participants question whether the relationship between beta and alpha is exact or only approximate, citing differing textbook interpretations.
  • One participant suggests that the relationship beta = 3alpha is exact when defined using derivatives, while it may not hold when using finite differences.
  • Another participant points out that the definitions of alpha and beta in certain textbooks lead to confusion regarding their exactness.
  • There is a discussion about the implications of small values of alpha on the validity of the relationship.
  • Participants express curiosity about the saturation of heat transfer by convection with increasing temperature differences, with one participant seeking further information on this phenomenon.
Participants do not reach a consensus on whether the relationship between beta and alpha is exact or approximate, and multiple competing views remain regarding the definitions and implications of these coefficients. The discussion on convection also lacks resolution.
Participants note that the definitions of the coefficients can vary, which may affect the interpretation of their relationship. There is also mention of the limitations of certain textbooks in conveying these concepts accurately.
Jerry Friedman
I have two questions on fine points of thermal physics.
1. Is an isotropic solid's volume-expansion coefficient beta exactly equal to 3 times its linear-expansion coefficient alpha, or is it only approximately equal? Some textbooks (Fischbane, Walker, Young) say the relation is exact, while others (Giancoli, Katz) say it's approximate. It's also possible to find books that say it's approximate, such as https://books.google.com/books?id=SwsNbiMDqzcC&pg=PA100 . In poking around the Web, I can't find anything that gives sufficiently precise experimental data or that gives anything but the simple argument about differentiating a cubic function--which I don't see anything wrong with, so why wouldn't it be exact. (Technically these constants are defined only in the limit of small temperature changes, right?)
2. Someone told me that the rate of heat transfer by convection typically saturates as Delta T increases, but didn't have any further information. I can't imagine why it would. Does anyone know anything about that?
I'd appreciate any information or any sources, especially those that don't require access to a university library.
Science news on Phys.org
Does (1 + α)3 = 1 + 3α? Or, something else?
I would be surprised if they say that. What is the exact :oldwink: wording?
If α is very small, then α2 is very very small and α3 is very very very small...
If ##\alpha## is defined as ##\alpha = \frac{1}{L}\frac{dL}{dT}## and ##\beta## is defined as ##\beta=\frac{1}{V}\frac{dV}{dT}##, then the relationship ##\beta=3\alpha## is exact.
If ##\alpha## is defined as ##\alpha=\frac{1}{L_0}\frac{L-L_0}{T-T_0}## and ##\beta## is defined as ##\beta=\frac{1}{V_0}\frac{V-V_0}{T-T_0}##, then the relationship ##\beta=3\alpha## is not exact.
My understanding is that the strictly correct way to define these coefficients is by the former, and not the latter. The latter is only used for beginners who are just being introduced to these concepts.
Chet
Thanks. Why would you be surprised?
Fishbane (correct spelling, sorry), Gasiorowicz, and Thornton: "We can show that β = 3α by considering a cube of volume V = L3." Then they differentiate.
Young and Freedman differentiate first, then say, "This is consistent with the infinitesimal form of Eq. (17.8), dV = βV0, only if β = 3α." (The last equation is displayed and numbered 17.9.)
Walker: "The coefficients of volume expansion and linear expansion for a solid are related by β = 3α." The equation is displayed, 18-11.
Chet
Thank you! That seems to be the answer, as both Giancoli and Katz define the coefficients in terms of ##\Delta##'s, not derivatives. I should have noticed.
Chestermiller said:
If α\alpha is defined as α=1LdLdT\alpha = \frac{1}{L}\frac{dL}{dT} and β\beta is defined as β=1VdVdT\beta=\frac{1}{V}\frac{dV}{dT}, then the relationship β=3α\beta=3\alpha is exact.
If α\alpha is defined as α=1L0L−L0T−T0\alpha=\frac{1}{L_0}\frac{L-L_0}{T-T_0} and β\beta is defined as β=1V0V−V0T−T0\beta=\frac{1}{V_0}\frac{V-V_0}{T-T_0}, then the relationship β=3α\beta=3\alpha is not exact.
Good catch! The textbooks that I've used (at least the introductory ones) must have all used the second definition.
  • · Replies 57 ·
9K
10K
21K
14K
