Thermal expansion, percent change in density problem
When the temperature of a metal cylinder increases from 0.0°C to 100°C, its length increases by 0.23%, which affects its volume. Since all linear dimensions of the cylinder expand by the same percentage, the volume change can be calculated using the formula for volume. The density change can then be determined by recognizing that mass remains constant while volume increases. This leads to a decrease in density, which can be expressed as a percent change. Understanding the relationship between length, volume, and density is crucial for solving this problem.
ctpengage
When the temperature of a metal cylinder is raised from 0.0°C to 100°C, its length increases by 0.23%. Find the percent change in density.
∆L = L∆T
p=m/v
I don't have any real idea how to start the problem. How do I relate the change in length to the change in volume? I know that mass is constant.
Thanks
How do you find the volume of a cylinder? Hint: All linear dimensions increase by the same percentage.
oh my god thanks so much
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
