AbsoluteZer0 said:
Thanks
Hypothetically speaking, if the question asked for the the final temperature of the Copper would the set up that I used be appropriate had the final temperature of water been given?
They would never ask it that way, since the copper and water have the same final temperature. Or did you mean to say something else?
As for your original equation, let's take a look at it again:
m_cC_c \Delta T_c = m_h C_h \Delta T_h
Think about what it is really claiming -- it is claiming that the same amount of energy enters both the copper and the water (imagine that the ΔT's are both positive). Where is that energy supposed to come from? This claim just doesn't make sense, and the equation
not saying that energy is conserved as was your intention in your original post.
We need to have a minus sign on one side of that equation. Then it would be saying the energy that leaves one substance equals the energy that enters the other substance. In other words, some energy can move from one substance to the other, and none of the energy can simply disappear, or appear out of nowhere. That is what conservation of energy means.
Note, in some examples worked out in a textbook or class lectures, people might define the ΔT's differently and write the equation you wrote. That is, for the hotter substance (copper here) they might really mean \Delta T = T_i-T_f, which is the opposite of what you called it, and equivalent to putting a minus sign in your equation as required.
Hope that helps clear things up.
