Thermodynamics - Adiabiatc Expansion
The discussion revolves around solving a problem related to the adiabatic expansion of an ideal gas, where 2.5 mol of gas does 2.4 kJ of work. The initial conditions provided include a pressure of 2.2 atm and a temperature of 50 degrees Celsius, with the initial volume calculated to be 30.15 L. Participants express confusion about determining the final temperature and volume, emphasizing the need for the gas's heat capacity to solve the problem accurately. The conversation highlights the challenge posed by the professor's ambiguous questions in a Biophysics course. Ultimately, the participants agree on the relevance of the adiabatic process equations to find the final state of the gas.
kineticwave
2.5 mol of an ideal gas which starts at 2.2 atm and 50 degrees Celsius does 2.4 kJ of work during an adiabatic expansion. What is the final volume of the gas? Express the result in the unit [m3].
V(initial) x T(initial)^(3/2) = V(final) x T(final)^(3/2)
I found the initial volume first using pV=nRT which I got to be 30.15L. But I'm not sure how to get the final temperature, nor the final volume for that matter.
What's the internal energy of the gas? How does a change in that relate to work done?
What I've posted is literally all the information I was given when asked to complete the question... my professor is known for his incomprehensible and ambiguous questions.
It is not possible to answer this question without knowing the heat capacity of the gas. You appear to be using 1/(γ-1)=3/2 which would make Cv = 3/2 and γ = 5/3
Are you told that this is a monatomic gas?
AM
The question posted is all that I'm given. This professor is known for questions like these. It's a course called Biophysics.
So how do you know that 1/(γ-1) = 3/2? (you have put this in your equation). Only a monatomic gas would have Cv=3R/2; γ=5/3.
AM
Just a thought
ΔU=nR∫(T/V)dV
where T can be represent by V
(VixTi)^3/2)=(VxT)^3/2=constant <-- calculate by sub initial conditions.
henry407 said:
Just a thought
ΔU=nR∫(T/V)dV
Ok except for a - sign. If Q = 0 then ΔU = -∫PdV
??How do you do that?
AM
Re AM:
(VixTi)^3/2=(VxT)^3/2=constant
isn't it, since the whole process is Adiabiatic Expansion, the above equation satisfy in any time during the process.
henry407 said:
Re AM:
Ok. I see what you mean. That will work.
AM
