vladimir69
- 124
A horizontal piston-cylinder system containing n mole of ideal gas is surrounded by air at temperature T_{0} and pressure P_{0}. If the piston is displaced slightly from equilibrium, show that it executes simple harmonic motion with angular frequency \omega=\frac{AP_{0}}{\sqrt{MnRT_{0}}}, where A and M are the piston area and mass, respectively. Assume the gas temperature remains constant.
PV=nRT
F=Ma
P=F/A
x=amount by which piston moves
L=length of cylinder
F = force on piston
V_{0}=AL
V=A(L-x)
F_{net}=A(P_{0}-P)
L=\frac{nRT_{0}}{P_{0}A}
P=\frac{ALP_{0}}{V}
Popping all this into the mix gives
F_{net}=\frac{-P_{0}^2A^2x}{nRT_{0}-P_{0}Ax}
M\frac{d^2x}{dt^2}=\frac{-P_{0}^2A^2x}{nRT_{0}-P_{0}Ax}
If I get rid of the P_{0}Ax} term then we arrive at the correct answer but not sure why one should throw away this term
Thanks
