Thermodynamics chemical reaction problem
The discussion revolves around calculating the work (w) and heat (q) for the reaction of sodium and chlorine gas to form sodium chloride at standard conditions. The user outlines the reaction and attempts to calculate the change in moles of gas, finding a delta(n(g)) of -1.16, leading to a calculated work of 2.87 kJ. However, this value does not match the textbook answer, prompting a consideration of whether the volume change can be applied using the formula w = pΔV. The conversation highlights the complexities of thermodynamic calculations in chemical reactions, particularly regarding gas behavior and heat transfer.
Benzoate
What are q and w (in kJ) for the reaction of 22 g of Na(s) and 82 g of Cl2(g) to produce NaCl at 1 atm and 298 K.
w=-delta(n(g))* R*T where delta(n(g)) = the moles of gas created during the reaction
First, I wrote the chemical reaction for Na and Cl2
2Na(s) +Cl2(g)=> 2NaCl
delta(n(g))=0-1 = -1
82 g Cl2*(1 mol Cl2/70.98 g Cl2)*(-1 mol gas/1mol Cl2)= -1.16
delta n(g) =-1.16
w=-delta(n(g))*RT=(-1.16)(8.314)(298 K)=2.87 kJ
But that's not the answer according to the back of my textbook.
The volume is changing from the volume of Cl2 gas to essentially zero.
Can one apply w = p \Delta{V}? 1 mole of gas has a volume of 22.4 l.
Then there is the heat.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
