How Much Energy Is Needed to Decompose 765g of PCl3?
To determine the energy required to decompose 765 g of PCl3, the molar mass of PCl3 (137.32 g/mol) is used to convert grams to moles, resulting in approximately 22.28 moles of PCl3. The enthalpy change for the reaction is +1207 kJ for 4 moles of PCl3, leading to a calculated energy of 6.72 x 10^3 kJ. However, the calculation is noted as incorrect, suggesting a potential error in the approach or sign used in the enthalpy conversion. Clarification is sought on the proper handling of moles and enthalpy in the calculation process. Accurate understanding of stoichiometry and enthalpy is crucial for solving this problem correctly.
KTiaam
How much energy is required to decompose 765 g of PCl3, according to the reaction below? The molar mass of PCl3 is 137.32 g/mol and may be useful.
4 PCl3(g) → P4(s) + 6 Cl2(g) ΔH°rxn = +1207 kJ
765 g PCl3 x 4 mol PCl3/137.32 g PCl3 = 22.28 mol PCl3
22.28 mol PCL3 x 1207 kJ/4 mol PCl3 = 6.72 x 103 kJ
Which is incorrect...I converted from grams to mols then i converted mols to kJ, which did not give me the correct answer.
Im probably using a wrong sign somewhere or completely approaching the problem correctly.
Thank you for your help
The highlighted operators are incorrect. Pay attention to number of moles in the equation for enthalpy.
the number of moles is 4? I got 4 from the balanced equation?could you explain more on what I'm doing wrong?
Step at a time: PCL3 is 137.32 gram per mole (gram mole, gram molecular weight), also written 137.32 g/mol. How many moles in 765 g?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
