Jtny179
- 2
A 4 cylinder car has 4 Pistons
The cycle is
1-2 : Adiabatic compression of air
- then injects fuel
2-3 : Burn Fuel
3-4 : Adiabatic expansion of gas
4-1 : Exchaust / Replace with fresh air
Diameter = 10 cm
Minimum depth 1 cm
Maximum depth 10 cm
Heating value of fuel is 2,100 j/g
Each cycle uses 0.005g of fuel
Temp of air = 25 degree celcius
Pressure of air = 101 325 Pa
Draw P-V Diagram
Calculate P,T,V at all points (1,2,3,4)
Calculate power produced by car at 100 RPM , 500 RPM and 1000 RPM
The cycle is
- then injects fuel
2-3 : Burn Fuel
Diameter = 10 cm
Minimum depth 1 cm
Maximum depth 10 cm
Draw P-V Diagram
