Thermodynamics: gas for stirling engine + liquid with high density
The discussion centers on building a model Stirling engine that operates on heat, specifically the SexBalloon-type engine using tin cans. The user seeks a gas that maximizes pressure increase with temperature while maintaining a constant volume, suggesting hydrogen or helium as potential options. Additionally, they are interested in a high-density liquid with a boiling point above 100°C that is safe and non-toxic, with a concentrated NaCl solution proposed as a viable option. The aim is to enhance the engine's power output by utilizing these gases and liquids effectively. Overall, the conversation highlights the need for safe, accessible materials to improve the engine's performance.
The Crazy Noob
Hi,
for the ones that don't like to read much (:smile:): the basic point is that I need a gas that gives as much pressure as possible with a temperature increase and a constant volume and that is easy to get my hands on; and a liquid with a high density (like mercury or something) that has a high boiling pont (preferably higher than 100°C), doesn't damage latex and isn't poisenous/dangerous.
I plan on building a model stirling engine (an engine that runs on heat) I've searched the web and found a nice, easy, little engine called the RotaColaSola engine, it should work on solar heat. (link: the original one (RotaColaSola) and the improved one (SexBalloon engine).
I would like to build the SexBalloon-type of engine (using balloons, no condoms :-p ) and I've started saving tin cans (empty catfood cans) because they are bigger and I have a bigger supply of them :smile:.
Now the actual question-part: While I'm waiting until I've got enough tin cans, I thought of a few improvements:
- If I would use a gas that, given a constant volume, produces more pressure with an equal temperature increase than plain air. (if it's explained badly I'll give an example: if the temperature increases with 10degC, the pressure of gas X increases with 10% while the pressure of regular air only increases with 5% -> twice as much power?) This will cause the liquid in the balloon to be pressed up more which should create more power. (my physics-teacher said something about hydrogen or helium?...)
- If I replace the water with a liquid that has higher density, the difference in weight will be greater when a same amount of liquid is pushed into the other reservoir and thus increasing the power. (example: if 1cc of water is moved, the weight that is moved is 1gram; if 1cc of liquid X is moved, the weight that is moved is equal to 2grams -> twice the power?) *note*: the boiling temperature would need to be as high as possible (the liquid must stay a liquid when heated with sun or with candle/flame/...)
I know that this forum is packed with physics-geniouses :wink: so if someone could please confirm the above or give other advice...
And does anyone know gasses and liquids that meet the above requirements, are easy to get and aren't dangerous?
Thanks,
The Crazy Noob
Science news on Phys.org
Just make a very concentrated solution of NaCl will be very dense and has pretty much infinite solubility so you can make it as dense as you like. Don't really know anything about gases off hand though.
lol, that just sounds so logical, can't believe i didn't think of that :blushing: :smile: (btw: the density of NaCl is 2.17 g/cm3, but i could use annything that is soluble in water...)
Thanks for the tip, now i just need a gas :smile:
** bump **
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
