Thermodynamics - heat flow of a rubber band
The discussion centers on calculating the heat flow of a rubber band when it is stretched isothermally from length L1 to L2, using the equation f = κT(L + γL²). Participants explore the relationship between energy change (dE), entropy (S), and the heat flow, focusing on integrating TdS to find the heat transfer. The conversation highlights the use of Maxwell relations to relate changes in entropy to force and temperature. Confusion arises around the correct formulation of dS and its dependence on the independent variables, leading to clarification on how to approach the integration. Overall, the thread emphasizes the importance of understanding thermodynamic relationships in this context.
mooshasta
Consider a rubber band for which the tension, f, as a function of temperature T and length L is f = \kappa T (L+\gamma L^2), where \kappa and \gamma are positive constants. Determine the heat flow between it and its surroundings when the rubber band is stretched reversibly and isothermically from length L_1 to length L_2.
dE = TdS + fdL + \mu dN
I think the question is asking to find \left( \frac{\partial E}{\partial L} \right)_{T,N} and integrate that. I'm not sure how to get this quantity, though, since I don't know what entropy is. Can I use the Helmholtz free energy when calculating heat transfer? I don't think so, since they are not equal...
Thank you for your help!
It's not \left(\frac{\partial E}{\partial L}\right)_{T,N}, since some of the energy change dE comes from strain energy, and you wouldn't include that in the heat flow. So you only want to integrate part of dE; which part is it? (Take a look at your equation.)
(Then I expect you'll get into the fun world of Maxwell relations.)
As I understand it, then, the heat flow should be \int TdS, since this is the heat part of the equation. So then should I be integrating:
T\int^{L_2}_{L_1} \left( \frac{\partial S}{\partial L}} \right)_{T,N} dL
Using a Maxwell relation as you said, I see that -\left( \frac{\partial S}{\partial L} \right)_{N,T} = \left( \frac{\partial f}{\partial T} \right)_{N,L}, and then the integral is straightforward.
I am just unsure if that integral above is correct, and if it is, what is the basis on getting that from \int TdS in this context.
Thanks! I appreciate your help.
Looks good to me!
I still am a little confused how to get to that integral. If S is a function of E, L, and N, doesn't that mean then that:
\left( dS \right)_{T,N} = \left( \frac{\partial S}{\partial E} \right)_{L,N} dE + \left( \frac{\partial S}{\partial L} \right)_{E,N} dL
But instead I wrote \left( \frac{\partial S}{\partial L} \right)_{T,N} dL. How does this match with the above equation?
Thanks again. I'm probably missing something pretty fundamental :)
Let's drop N, since it's constant here. S is a function of two independent variables. We could write
dS=\left(\frac{\partial S}{\partial E}\right)_LdE+\left(\frac{\partial S}{\partial L}\right)_EdL
or
dS=\left(\frac{\partial S}{\partial T}\right)_LdT+\left(\frac{\partial S}{\partial L}\right)_TdL
The first isn't of much use; the second simplifies into the integrand above. Does this make sense?
I think I get it now, thank you. I didn't realize that one of the independent variables could be the conjugate (T).
Thanks!
