Thermodynamics Question and My Answer
  • Thread starter Thread starter Altairs
    Thermodynamics
Altairs
[SOLVED] Thermodynamics Question and My Answer
During a cloudy day of the summer season, a driver inflates his car tyres (max allowed pressure is 44PSI(Gauge)) to 38PSI(Gauge) at a petrol station. the temperature of the air inside one of the tires is 77^oF and volume of the tire is 1ft^3. Later, the sun comes out and the air inside the tire experience a temperature rise of 36^oF. Assuming the volume to be constant determine whether the tire will burst or not.
P(Absolute) = P(Ambient) + P (Gauge)
Conversion from F to R
Conversion from PSI to \frac{lbf}{ft^2}
First did the relevant conversions.
Then used :-
P_{1}v = RT_{1}
P_{2}v = RT_{2}
Where R = Individual Gas Constant
Where v = Specific Volume
Took the ratios, because the volume remains constant and so does the value of R :-
\frac{P_{1}}{P_{2}} = \frac{T_{1}}{T_{2}}
Made relevant calculations and then did reverse conversions. Got the answer to be 41.54 PSI (Gauge). Which indicates that tire doesn't bursts. Is this the correct answer ?
Yes.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
