[Thermodynamics] Temperature change during cooling of a gas
The forum discussion centers on the comparison of temperature changes during the cooling of a gas through two methods: adiabatic throttling (Joule-Thomson Experiment) and reversible adiabatic expansion. It is established that when both processes start and end at the same initial and final pressures, the temperature difference achieved by reversible adiabatic expansion is always greater than that of adiabatic throttling. Key thermodynamic equations, including the definitions of expansivity (β), isothermal compressibility (κ), and heat capacity at constant pressure (cP), are utilized to derive the relationships between temperature and pressure changes in both processes.
  • Understanding of thermodynamic potentials and equations of state
  • Familiarity with the Joule-Thomson coefficient and its implications
  • Knowledge of Maxwell Relations in thermodynamics
  • Basic calculus for integrating differential equations
  • Study the Joule-Thomson effect in detail, focusing on its applications in gas cooling
  • Learn about the derivation and implications of Maxwell Relations in thermodynamics
  • Explore the concepts of expansivity (β) and isothermal compressibility (κ) in various gases
  • Investigate the conditions under which adiabatic processes occur and their significance in thermodynamic cycles
Students and professionals in thermodynamics, particularly those studying gas cooling methods, engineers working with refrigeration systems, and researchers in physical chemistry.
mef51
One method for cooling a gas is adiabatic throttling (Joule-Thomson Experiment). Another method is a reversible adiabatic expansion. Show that if the initial and final pressures are the same, the difference in temperature obtained by the second method is always higher.
Hint: Express ##\frac{\partial T}{\partial P}## in each process as a function of the expansivity ##\beta##, the isothermal compressibility ##\kappa## and ##c_P## and compare the results.
The question has to do with thermodynamic potentials.
\beta=\frac{1}{V}\Big(\frac{\partial V}{\partial T}\Big)_{P} \\
\kappa=-\frac{1}{V}\Big(\frac{\partial V}{\partial P}\Big)_{T} \\
c_{P}=\frac{T}{n}\Big(\frac{\partial S}{\partial T}\Big)_{P}
Cyclic Relation:
$$\Big(\frac{\partial T}{\partial P}\Big)_{S}\Big(\frac{\partial P}{\partial S}\Big)_{T}\Big(\frac{\partial S}{\partial T}\Big)_{P}=-1$$
Reciprocal Relation
\Big(\frac{\partial x}{\partial y}\Big)_{z}=\Big(\frac{\partial y}{\partial x}\Big)_{z}^{-1}
The temperature is a function of ##S## and ##P## so
$$T(P,S) \implies dT=\Big(\frac{\partial T}{\partial S}\Big)_{P}dS+\Big(\frac{\partial T}{\partial P}\Big)_{S}dP$$
The Maxwell Relations are also relevant.
Using the cyclic and reciprocal relation and the definitions of ##\beta##, ##\kappa## and ##c_P## I can get that, for the second process
\Big(\frac{\partial T}{\partial P}\Big)_{S}=\frac{\beta VT}{nc_{p}}
To get the change in temperature I integrate the differential. Since the second process is reversible ##dS=0## so
\Delta T=T_{f}-T_{i}=\int_{P_{i}}^{P_{f}}\Big(\frac{\partial T}{\partial P}\Big)_{S}dP
But since the final and initial pressures are the same this change in temperature is always 0! How can it ever be greater than the temperature difference in the first method? What am I missing here?
Let's insert, "for both processes," right in here, and see how it works.
(snip)What am I missing here?
Hm okay well for adiabatic throttling I know that the Joule-Thomson coefficient ##\mu## is positive when a gas is cooling so we know that ##\mu \equiv \Big( \frac{\partial T}{\partial P} \Big)_H > 0##.
Using the fact that the adiabatic throttling is a constant-enthalpy process you can show that
\Big(\frac{\partial T}{\partial P}\Big)_{H}=\frac{V}{nc_{p}}(\beta T-1)=\frac{\beta VT}{nc_{p}}-\frac{V}{nc_{p}}
I notice that ##\Big(\frac{\partial T}{\partial P}\Big)_{S}## is related to this expression and we have
\Big(\frac{\partial T}{\partial P}\Big)_{H}=\Big(\frac{\partial T}{\partial P}\Big)_{S}-\frac{V}{nc_{p}}
But even with this if I go to do the integral to find ##\Delta T## I still get zero because the final and initial pressure's are the same... ##dP=0##!
Since ##\frac{V}{nc_p}## is positive I can see that
\Big(\frac{\partial T}{\partial P}\Big)_{S}>\Big(\frac{\partial T}{\partial P}\Big)_{S}-\frac{V}{nc_{p}}=\Big(\frac{\partial T}{\partial P}\Big)_{H}=\mu>0
But I don't understand how that would imply the temperature difference being greater. They both seem to be 0
The intial pressure is the same for both processes, the final temperature is the same for both processes, but the initial temperature is not the same as the final temperature.
The initial and the final pressures are the same.
How do you know that? I could equivalently say that the initial temperatures are the same for both processes and the final temperatures are different. Further, it's not even necessary that any of the temperatures are the same. We just want to show that cooling by the second method gives a larger temperature difference than the first method. (EDIT: misread). I know that the initial and final temperatures must be different which is why I'm confused that the integral that gives ##\Delta T## gives 0
Because you can neither have adiabatic expansion nor throttling at constant pressure. You are misunderstanding the problem, as Bystander also tried to tell you.
So the pressure starts and ends at the same point but changes in between?
How can you do a reversible adiabatic expansion of a gas if the initial and final pressures are the same? How can you throttle a gas adiabatically if the initial and final pressures are the same?:confused:
Chet
I dunno! On a PV diagram an adiabat with constant pressure doesn't really make sense either.
Let's say that we don't have this condition that the initial and final pressures are the same. Then we'd have that the temperature difference for each method is
\newcommand{\pderv}[3]{\Big(\frac{\partial#1}{\partial#2}\Big)_{#3}}
\Delta T_{1}=\int_{P_{i}}^{P_{f}}\pderv TPHdP\qquad\Delta T_{2}=\int_{P_{i}}^{P_{f}}\pderv TPSdP
which means, since ##\pderv TPS>\pderv TPH##
$$\Delta T_{2}>\Delta T_{1}$$
I checked that I didn't copy the question down wrong. Maybe it's a typo
Quod erat demonstrandum.
Indeed
It's not a typo. I've been guilty myself of writing questions with that kind of formulation (in exams, no less). What happens is that the meaning of "the initial and final pressures are the same" is evident in the mind of the person writing the question, to the point of not realizing it can be misconstrued.
Ohh haha the lightbulb just clicked.
Perhaps the unambiguous way of phrasing it would be
"Show that if both processes start at an initial pressure ##P_i## and end at a final pressure ##P_f##, then the difference in temperature obtained by the second method is always higher."
Yes. That would have been much, much, much, much better. The original version confused lots of us.
Chet
