Thevenin theorem and norton theorem
  • Thread starter Thread starter stupif
    Theorem Thevenin
Thevenin's and Norton's theorems are essential tools in electrical engineering for simplifying complex circuits into manageable forms. They allow engineers to represent entire circuit sections as simple voltage or current sources with resistors, facilitating easier analysis. This abstraction helps in focusing on specific parts of a circuit without getting bogged down by unnecessary details. The use of these theorems enhances efficiency in circuit design and troubleshooting. Overall, they contribute significantly to the field by streamlining circuit analysis processes.
stupif
can someone tells me what is purpose of using thevenin"s and norton"s theorem??
and what these theorems contribute to electrical engineering's field?
thank you
What's the purpose of a ball-peen or framing or sledge hammer? They're all used to hit things with, but are better at particular jobs. So it is with Thevenin's and Norton's: they're both used for circuit analysis, but can greatly simplify certain jobs, and allow you to abstract entire portions of simple circuits, reducing them down to a simple voltage or current source and a resistor.
The whole concept of black boxes and abstraction makes EE's lives easier.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
