Thickness of hot chocolate varying with temperature
The viscosity of hot chocolate changes with temperature due to the evaporation of water and the settling of chocolate particles. When left at room temperature, hot chocolate thickens as water evaporates, concentrating the chocolate. Conversely, rapid cooling in a refrigerator minimizes evaporation, resulting in a thinner consistency. The settling of chocolate particles also contributes to perceived viscosity, as stirring does not fully restore the original thickness when cooled.
  • Understanding of fluid dynamics
  • Knowledge of thermal properties of liquids
  • Familiarity with colloidal suspensions
  • Basic principles of evaporation and condensation
  • Research the thermal properties of chocolate and its behavior in different temperatures
  • Study colloidal suspension stability and its impact on viscosity
  • Explore the effects of evaporation on liquid mixtures
  • Investigate the principles of heat transfer in liquids
Chemists, food scientists, culinary professionals, and anyone interested in the physical properties of food and beverages.
Arak
I noticed recently that hot chocolate when left on the table for a while and starts cooling at room temperature, starts getting thicker (more viscous). However, when it was put in the fridge overnight and got completely cold it became more liquid (less viscous). Why does this happen? Can someone please help me understand this? Thanks.
Science news on Phys.org
If you leave it out, it takes a while for the hot chocolate to cool. During this time water is evaporating as steam, which removes the water from the mug but leaves the chocolate. Putting it inside a refrigerator cools it down much quicker, which would allow less water to escape. However, I think the key difference here is that hot chocolate left overnight tends to settle at the bottom of the mug. Hence it is less viscous when you take a sip because half the chocolate is at the bottom.
Thank you for your response. But I was wondering, the hot choco has already lost some water which is what makes it thick and it's the same mug that was put in the refrigerator, so how does it regain the lost water?
Also, even if the chocolate had settled in the bottom, after stirring it, it was still not as viscous as it was when it was hot. Why is that?
  • · Replies 66 ·
  • · Replies 32 ·
  • · Replies 42 ·
