This magnet question confounds me
  • Thread starter Thread starter lodovico
    Magnet
The discussion revolves around a physics problem concerning the relationship between the magnetic field (B-field) and the radius (R) of a charged particle's circular motion. The participants debated between two graph choices: a straight line with a negative slope (Choice H) and a hyperbolic graph (Choice J). The correct relationship derived from the equations shows that as the B-field increases, the radius decreases, leading to the conclusion that the graph representing this relationship is hyperbolic (Choice J). The term "Larmor Radius" is mentioned, indicating the established concept related to this phenomenon. The final consensus supports that the hyperbolic graph accurately depicts the inverse relationship between B-field and radius.
lodovico
Today, my teacher gave us some practice AP multiple choice and my friend and I were debating between answer choices H and J (changed from A and B to remove any confusion) the question as i remember it:
blah blah... B-field into the page, constant velocity v, radius R and charge q. which graph shows the relationship between B-field and radius.. something with radius getting smaller as B-field gets larger
Choice H: this is a straight line coming from +y crossing the +x axis (basically a straight negative slope)
Choice J: the (1/x) graph with x>0
Fc = mv^2/r
Fb= qvB
Fc=Fb
\frac{mv^2}{r}=qvB
\frac{mv}{r}=qB
since mv and q are constants, is it ok to treat them as 1? that is what i did so...
\frac{1}{r}=B
\frac{1}{B}=r
since on the graphs r was the y-axis and B was the x-axis
i chose the (1/x) shaped graph
Fc = mv^2/r
Fb= qvB
Fc=Fb
\frac{mv^2}{r}=qvB
\frac{mv}{r}=qB
\frac{1}{r}=B
\frac{1}{B}=r
Yes, it is known as the Lamor Radius:
http://www-fusion.ciemat.es/fusionwiki/index.php/Larmor_radius
:smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
