Threshold Frequency: Equation & Electron Release
The threshold frequency is defined as the minimum frequency required for a photon to free an electron from a material, represented by the equation W = hf₀, where W is the work function, h is Planck's constant, and f₀ is the threshold frequency. This frequency corresponds to the minimum energy needed to bring an electron to the surface of a material, but not necessarily to eject it completely. In the context of the photoelectric effect, the full energy equation is Eₚₕₒₜₒₙ = W + Eₖₘₐₓ, where Eₖₘₐₓ represents the maximum kinetic energy of the ejected electron. When the kinetic energy is zero, the equation simplifies to derive the work function in terms of the threshold frequency.
Gogsey
What is the equation used to solve for the threshold frequency?
Is the threshold frequency the minimum amount of energy requird to free an electron from the nucleus?
W=hf_{0}
where W is the work function, h is Planck's constant, and f_{0} is the threshold frequency. I believe the answer to your second question is yes.
We talk of threshold frequency because the energy of the photon is h*f. That energy should be sufficient enough to knock out the electron.
To be precise this is just sufficient energy to bring an electron to the surface but not quite to knock it out of the metal. (Again this depends on how you interpret "knock out"). Thats why in the so called Einstein equation for photoelectric effect, there's a second term which accounts for the kinetic energy of the ejected photoelectron...if this term were zero, the electron would--in principle--stay there.
That is true. The full equation is
E_{photon}=W+E_{K}_{max}
As you can see, the equation for W as a function of threshold frequency is derived from this by setting the kinetic energy of the photoelectron to zero.
Likes wajahat ali
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
