Throwing a Ball from a Roof: Calculating Velocity & Angle
The problem involves a ball being thrown from a height of 35.0 meters, landing 29 meters away from the base of the building. The maximum height of the ball's trajectory is noted to be 12 meters above the release point. The discussion focuses on calculating various components of the ball's motion, including initial vertical velocity, total flight time, horizontal velocity, and launch angle.
  • Participants discuss the use of kinematic equations to analyze the motion of the ball. There are attempts to confirm initial velocity calculations and questions regarding the appropriate equations to use for different components of the problem. Some participants express uncertainty about their results and the methods used to derive them.
The discussion is ongoing, with participants sharing their attempts at solving the problem and seeking confirmation of their calculations. There is a focus on clarifying the relationships between the variables involved, particularly at the maximum height of the ball's trajectory.
Participants note a lack of confidence in their answers and express frustration with the problem. There is an emphasis on understanding the underlying physics rather than simply arriving at numerical solutions.
bricker9236
A ball is thrown OFF a roof at a height 35.0m above ground. The ball hits the ground 29m from the base of the building. the max height of the balls trajectory is 12 m above the height from which the thrower released it.
a) find the initial vertical component of the velocity.
b) find the total time that the ball is in flight (from the time it is thrown until it lands on the ground)
c) find the horizontal compoent of the initial velocity required for the ball to land 29 m away from the building.
d) at what angle is the ball thrown from the roof? (measure angle above horizontal =0 degrees)
Not sure, I was just randomly trying to figure it out and this problem frustrated me.
a) 10.9 .. that is the answer i got, if anyone could confirm or help me out.
b) 2.22 seconds
c) 14.23 m/s not sure, again
d) 40 degrees again, not very sure .. i used tan inverse of 12/29 wasnt sure if it shiould be tan inverse of (35+12)/29 not sure
So let's use these
[tex]y=y_0 +ut -\frac{1}{2}gt^2[/tex]
[tex]v^2=u^2-2g(y-y_0)[/tex]
[tex]v=u+at[/tex]
u=initial velocity
v=final velocity
y0=initial height.
b) 2.22 seconds
Can't really check your answers if you yourself don't know how you got them.
Now we start, let's call the vertical component of velocity vy and the horizontal vx
We are given the maximum height as 12m from the height thrown. What do you know about the final vertical velocity at the maximum height?
the final vertical velocity at max height would be 0 bc at any max height the velocity is always 0
Right, so using vy=0, in our possible equations containing v, we can get
[tex]0=u^2-2g(y-y_0)[/tex]
or
[tex]0=u+at[/tex]
Which would you like to use or which do you think is better to use?
  • · Replies 31 ·
  • · Replies 38 ·
  • · Replies 32 ·
