Velocity of a Ball Thrown from a Building
  • Thread starter Thread starter chawki
    Air Ball
A ball is thrown upward from a 48 m tall building with an initial velocity of 12 m/s, and the discussion focuses on calculating its velocity upon reaching the ground. The correct approach involves using the equation V² = V₀² + 2aΔh, where 'a' is the acceleration due to gravity (-9.81 m/s²) and Δh is the height (-48 m). The final velocity is calculated as approximately 32.95 m/s, regardless of whether the ball is thrown up or down, due to the conservation of energy. The discussion emphasizes the importance of sign conventions in physics equations to avoid confusion. Ultimately, understanding the relationship between initial velocity, height, and acceleration is crucial for solving such problems.
chawki
A ball is thrown up from the top of a 48 m tall building with an initial velocity of 12 m/s.
What is the velocity of the ball at the ground?
V=-9.81*t+12 ?
hi chawki! :smile:
you need one of the other constant acceleration equations …
yours uses vi vf a and t, but you don't know t :redface:
you need one that uses vi vf a and s :wink:
just use v2 = u2 + 2as
chawki said:
V=-9.81*t+12 ?
That's the velocity as a function of time. What about the position?
it shouldn't be V2-V02= - 2*g*h ? since we are throwing upward.
and we don't know how much the ball got higher before falling
i gave you the eqn in original ... you should the direction yourself
V2=(-2gh)+V02
V=28.24 m/s ?
chawki said:
V2=(-2gh)+V02
V=28.24 m/s ?
no
isn't -2gh positive ?
chawki said:
V2=(-2gh)+V02
That's fine. (Assuming you use the correct value for h, which really should be Δh.)
V=28.24 m/s ?
But you messed up somewhere. Show what you plugged in where.
That equation doesn't depend on the direction in which you throw. The negative sign is correct because the acceleration is -g (taking down as negative). But what's 'h'? That's where sign is also important.
v2 and u2 will be positive no matter what
what do you think will be signs of s and a ?
tiny-tim said:
no
:blushing:
i understand Δh=-48m ? ( but still i wonder how much the ball got higher when we throw it upward)
well..if Δh=-48
V= \sqrt{}-2*9.81*-48+12^2
V= 32.95 m/s
V= 32.95 m/s
Yes its right
And next time wry writing "-2*9.81*-48+12^2" inside the bracket of sqrt in latex ... LOL ... :smile:
Good.
That's a different problem, but you can use the same equation to solve it. In that case you'd be solving for Δh.
Doc Al said:
Good.
ok, so i understand it doesn't change anything in our solution how much the ball got higher? we use only the height from the initial throw to the ground ?
That's right. When the ball comes back down to its initial level, it's going at the same speed it started out at. We don't need to know how high it went.
That's very interesting.. Thank you so much :blushing:
so it's like we throwed the ball downward with an initial speed?
and in that case..wouldn't be V2-V02 = 2*g*h ?
with h=-48m
and then we have a problem..we can't find the root of a negative number...
Right. Whether you throw the ball up or down, you'll get the same speed when it reaches the ground. Obviously throwing it up means its trip to the ground takes longer.
No. The equation doesn't change. It's the same regardless of the direction you throw.
with h=-48m
That's because you made the acceleration positive. But gravity still acts down.
I have learned that the equation of throwing a ball downward is typicall to free fall eauation..which is: V2-V02 = 2*g*h
That equation should be:
V2-V02 = -2*g*Δh
The minus sign is important. (a = -g = -9.8 m/s^2)
<offtopic post>
I had the change the title: I couldn't keep reading the title "throwing up"!
V2-V02 = -2*g*Δh
are you saying that in case of free fall, we write: V2-V02 = -2*g*Δh
Yes.
cristo said:
<offtopic post>
:smile: Yeah, not the best title choice.
sorry :blushing:
I'd have changed it to "throwing up (sic)" :biggrin:
and then washed my hands of it! o:)
v2-u2 = 2gΔh is the eqn in its pure form ...
to use it ... just choose anyone direction (up or down) as positive(just like Y axis) and other as negative(obvious)
and then write the values with signs corresponding to your direction ...
like ... if you choose up as positive then eqn would be ...
v2 - 122 = 2(-9.8)(-48)
v2 - 122 = 2(9.8)(48)
thus v = 32.95 m/s
and in case you throw the ball down ... (taking up as positive)
v2 - (-12)2 = 2(-9.8)(-48)
so you get same answer
... and this is in very obvious ...
when you throw the ball up ... it goes to max height and then return to the thrower's level having same speed 12 but now downwards ... so obviously of you initially throw the ball downwards ... it will still gain same speed when it reached the bottom
thus v = 32.95 m/s
Let me get this right,
in case of falls and throwing down with initial speed, the equations are:
h=1/2*g*t2+V0*t
V=g*t+V0
V2-V02=-2*g*Δh ?
in case of throwing the ball upward, the equations are:
h=-1/2*g*t2+V0*t
V=-g*t+V0
V2-V02=-2*g*Δh ?
h=1/2*g*t2+V0*t
V=g*t+V0
V2-V02=-2*g*Δh ?
h=-1/2*g*t2+V0*t
V=-g*t+V0
V2-V02=-2*g*Δh ?
No. The equations should be the same for both cases. The acceleration is always downward, a = -g.
The only difference between throwing the ball upwards versus throwing it downwards is the sign of V0: In one case, V0 = +12 m/s (for example); in the other, V0 = -12 m/s.
  • #31
i think it's -12 in the case of free fall ?
  • #32
"Free fall" just means that the only force acting is gravity. However you throw the ball--up, down, or sideways--once it leaves your hand it's in free fall. (Ignoring air resistance, of course.)
  • #33
That's confusing :(
in another problem, there was an object at the roof of a building, then it falls..
they asked the time it takes the object to reach the ground..and if i use (as you told me)
h=-1/2*V*t^2 ..i won't get t...
my mind is messed now
  • #34
and same thing if i want to find the velocity when that object hits the ground...
  • #35
chawki said:
That's confusing :(
To be consistent, you should use:
Δh = -1/2gt^2
Works fine. What would you use for Δh?
(If you let down be positive, then you can use h = 1/2gt^2. But let's get the standard convention straight before changing things.)
  • #36
What equation are you using?
  • #37
Δh = -1/2gt^2
Δh=final distance-initial distance
but since you talked about the possibility of writing h = 1/2gt^2 , please please please tell me what i should change in the equations that i wrote in post #30
i prefer using down as positive direction
  • #38
Why?
  • #39
Doc Al said:
Why?
i guess that way he doesn't have to worry about sign of g
i also used to do it when i started studying physics
  • #40
Doc Al said:
Why?
i just prefer...i used to it when i was at school...and i have an important exam to take..and not enough time to revise everything..and using the down direction as negative will just add more stress on me and confuse me more
  • #41
yes ..thank you...you are right...i don't want to take care about the sign of g or V...i just want the correct equations for ''down as positive''
  • #42
If you use a standard sign convention, you never have to worry about the direction of gravity.
Sure, me too. But I strongly suggest that one learn the standard method that applies to all problems. Once you've mastered that, then you can take short cuts.
  • #43
Here's how to figure it out:
Start with the general equations for uniformly accelerated motion. You can find them here: https://www.physicsforums.com/showpost.php?p=905663&postcount=2"
To apply them to free fall with down = positive, use a = g.
To apply them to free fall with up = positive, use a = -g.
Done!
(But don't be surprised if you mess things up, since now you have to remember multiple equations. The 'down as positive' method is fine when nothing changes direction, such as when you throw something downward. Not so good when you throw things up, since they then come down.)
  • #44
i know what you mean...but I DON'T HAVE TIME :(
  • #45
cupid.callin please HELLP ME if you have the equation for both cases (free falls, throwing downward) and (throwing upward)
  • #46
Here you go:
h=1/2*g*t2+V0*t
V=g*t+V0
V2-V02=-2*g*Δh ?
h=-1/2*g*t2+V0*t
V=-g*t+V0
V2-V02=-2*g*Δh ?
Here are the equations if up = positive (a = -g):
y = y0 + v0t - 1/2gt^2
(or Δh = v0t - 1/2gt^2)
v = v0 - gt
V2-V02 = -2*g*Δh
If you prefer down = positive, just change the sign of g (a = +g):
Here are the equations if up = positive:
y = y0 + v0t + 1/2gt^2
(or Δh = v0t + 1/2gt^2)
v = v0 + gt
V2-V02 = 2*g*Δh
  • #47
DOC AL is helping you and you are asking for my help ...
He is far more intelligent that both of us combined (Thats why he's a mentor ... LOL)
Anyway ...
these 3 eqn's will solve all your problems (provided you use them correctly)
v = u + at
s = ut + 0.5at2
v2 = u2 + 2as
and always remember that v,u,a,s (and s is displacement not distance)are all vectors (not used as vectors there though)
do it simple and step by step
lets do a question ...
suppose you throw a ball up with speed 50 m/s ... what will be its speed and height after 2 sec
(use appropriate eqn and solve)
  • #48
Anyway ...
v = u + at
s = ut + 0.5at2
v2 = u2 + 2as
y=1/2*g*t2+V0*t = 119.62 m
V=g*t+V0=69.62 m/s
  • #49
V=g*t+V0=69.62 m/s
So you think if i launch something with m/s upwards .. it will increase its speed?
you you can go into space by just jumping ...?
Imagine the problem ... how it will proceed
and if vo is positive then g will be ?
  • #50
i think that if vo is positive then g will be negative
y=-1/2*g*t2+V0*t = 80.38 m
V=-gt+v0 = 30.38 m/s
