Time needed to cross river - depends on flow of the water?
The time required to swim across a river is indeed influenced by the flow rate of the water. When swimming perpendicular to the current, the swimmer's effective speed is altered by the flow; swimming with the current increases speed, while swimming against it decreases speed. Factors such as the river's width and the swimmer's trajectory also play crucial roles in determining crossing time. The discussion highlights the importance of clarifying assumptions about the river's characteristics and the swimmer's path. Overall, the flow of water significantly affects the time taken to reach the opposite shore.
parker21
When you swim across a river does the time to reach the opposite shore depend on the rate of flow of the water? Defend your answer
What do you think?
Couple hints: since it isn't stated in the problem, what do you want to assume about the width of the river; and, what do you want to assume for a relationship between the starting and ending points for your swim?
The time is affected if the rate of flow has a component perpendicular to the path of the river, or if the river gets wider or narrower downstream, or if the rate of flow causes the water to get turbulent (probably other factors as well). You left out a lot of constraints in your original post.
Will the speed of the water flow influence the speed of the swimmer (assuming that he always swim at the same speed) ?
yes, when you are traveling in the direction of flow your speed increases (as the speed of the flow is added to your own speed).similarily when you are going against the flow your speed reduces (as the speed of flow is restricting and is subtracted from your own speed).o:)
...but that's not really across the river, is it?
Think about a flow down the river as you swim across it and, like said before, the width of the river and distance swam.
Can we please require the OP present his/her thoughts before everyone else jumps in with their ideas?
Huh? http://img228.imageshack.us/img228/835/policexn6.gif
It looked like the OP had drawn a conclusion - which didn't really go along with the question posed.
All the OP did was post the question!
As Gokul said, please resist the temptation to jump in prematurely. :cool:
Oops :redface:
I thought the robi person above me was the OP :redface:
Sorry!
And sorry Gokul - I thought you were enforcing the law o:)
