Time of maximum displacement in simple harmonic motion?
In summary, the equation for the velocity at any given time is x=Asin(wt+f). The equation for the displacement at any given time is x=Asin(wt+f). The equation for the mass at any given time is m=f+A.
liltiga
I am completely and totally lost...
The motion of an object is simple harmonic with equation of motion x = (27.1 m) sin(16.0 t /s + 0.7). At what time after t = 0 will the displacement reach its first maximum (where velocity equals zero)?
x = Asin(wt)
x = Asin(wt)
x = Asin(wt +...) The 0.7 means something in this equation... And do you know what the maximum displacement is from the equibrium position by just looking at the equation you were given?
Another way of looking at it... Do you have an equation for the velocity at any given time?
oh, sorry it's x=Asin(wt+f), I think.
No, it didn't give me the displacement from equilibrium, I gave all that I had for it.
Another way of asking the same question is the equation consists of two parts:
A, the amplitude (maximal displacement) and a time varying function given by sin (some function).
Since A = 32 = constant, the maximal value will occur when sin (some function) = 1. This of course will happen over and over as sin varies between -1 and 1. But it is asking for the value of t when this first occurs. So what you need to solve for is when the argument of the sin is equal to pi/2 radians(90 degrees). In other words (16t + 0.7) = pi/2.
The other approach using knowledge of min, max and first derivatives is to take the derivative of the function 27.1 sin (16t+0.7). and solve for when that will be zero.
Well actually its A, as long as the entire part sin(wt + f) = 1.
But because your mass or whatever is at a starting position of f, then the mass is going to move in some amount of time to get to A. f is some starting position, the position at t = 0s.
So I have given you one hint with the first equation on how to find the time where sin() = 1 meaning the object would be at its maximum displacement from equilibrium.
Another way is to get the velocity equation with respect to time. You have the position equation with respect to time. So if you know the velocity equation, you can set V(t) = 0 m/s or w(t) = 0 rad/s and get the time where the object that is oscillating is at its maximum displacement. Have you been given the velocity equation for SHM, or have you been shown how to take the derivative of the position equation with respect to time to get the velocity function with respect to time for SHm?
Whoops I see the other poster has said somewhat the same thing.
1. What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion where the restoring force on an object is directly proportional to its displacement from equilibrium. This means that the object will oscillate back and forth around a central point, with a constant frequency and amplitude.
2. How is the time of maximum displacement in simple harmonic motion calculated?
The time of maximum displacement in simple harmonic motion can be calculated using the formula T = 2π√(m/k), where T is the time period, m is the mass of the object, and k is the spring constant. This formula can also be written as T = 2π/ω, where ω is the angular frequency.
3. What factors affect the time of maximum displacement in simple harmonic motion?
The time of maximum displacement in simple harmonic motion is affected by the mass and spring constant of the object, as well as the initial displacement and velocity. It is also affected by external factors such as friction and air resistance.
4. How does the time of maximum displacement change with different frequencies?
In simple harmonic motion, the time of maximum displacement is directly proportional to the frequency. This means that as the frequency increases, the time of maximum displacement also decreases. Conversely, as the frequency decreases, the time of maximum displacement increases.
5. Is the time of maximum displacement the same as the time period in simple harmonic motion?
No, the time of maximum displacement is not the same as the time period in simple harmonic motion. The time period is the time it takes for one complete cycle of oscillation, while the time of maximum displacement is the time at which the object reaches its maximum displacement from equilibrium. However, they are related, as the time of maximum displacement occurs halfway through the time period.
