Time required for recovery from compression
  • Thread starter Thread starter Ngineer
    Compression Time
The discussion focuses on modeling the recovery time of a thin polymer layer after pressure is released. The initial approach suggested is based on Newton's second law, considering acceleration and gravity's impact on the device's orientation. However, it is noted that gravity and inertia may be negligible in this context. The dominant factor in the recovery process is likely the viscoelastic behavior of the polymer, which should be researched further. Understanding viscoelasticity is crucial for accurately predicting the recovery time of the polymer layer.
Ngineer
Hello everybody,
As a university project, we are designing an electronic device in which the output depends on the current thickness of a thin polymer layer (typically around a few microns) which is subject to different levels of pressure and thus different levels of compression.
I am interested in understanding how to model the time it takes the polymer layer to recover to its original thickness, say the pressure instantaneously dropped to the original "zero" level.
Although I stand to be corrected, I believe a good place to start is Newton's second law (f=ma), and accounting for gravity based on device orientation at operation. Once a value for acceleration is found, the time required to reach a specific length can then be easily computed.
If this is a valid approach, which mass do I use in that formula? Is it the entire mass of the material that forms the layer?
Your help is greatly greatly appreciated!
Gravity and inertia in this type of situation are likely to be insignificant. The response of the polymer layer is likely to be dominated by the time-dependent viscoelastic behavior of the polymer. Google Viscoelasticity.
Likes Ngineer
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
