bemigh
- 29
Hey,
Im having a lot of difficulty with this certain problem...
The rubber tire has two sidewalls of uniform thickness 0.688 cm and a tread wall of uniform thickness 2.60 cm and width 21.1 cm. Assume that L1=17.9 cm, L2=29.0 cm and L3=31.6 cm. Suppose its density is uniform, with the value 1.09×103 kg/m3. Calculate its moment of inertia about an axis through its center perpendicular to the plane of the sidewalls.
The image provided has L1 showing the radius of the rim, L2 being the radius from the center of the rim to the inner edge of the tread, and L3 from the radius from the center of the rim to the outer edge of the tread. I've already used many guesses, because i thought i could find the volume of the tire, then use it to find the mass of the tire, thus calculating the moment of Inertia using the radius of the tire, but it still didnt work... any ideas or clarifications would be awesome,
Cheers
Cheers
