Torque and Rotational Kinematics
The discussion focuses on a physics problem involving a grindstone coming to rest due to applied force and friction. The key equations include torque (τ), moment of inertia (I), and angular acceleration (α). The user attempts to derive the coefficient of kinetic friction (μk) but confuses the forces acting on the grindstone, particularly the torque produced by friction versus the applied force. Clarification is provided that the torque causing deceleration is due to friction, not the normal force applied. The conversation emphasizes the importance of correctly identifying forces and their contributions to the system's motion.
zbobet2012
A grindstone in the shape of a solid disk with diameter 0.490 m and a mass of m = 50.0 kg is rotating at omega = 890 rev/min. You press an ax against the rim with a normal force of F = 170 N, and the grindstone comes to rest in 7.20 s.
τ=Iα
ωz0zkαt
τ=r×F
\tau =I\alpha
{\omega }_z={\omega }_{0z}+{\mu }_k\alpha t
I=\frac{1}{2}MR^2
\tau =\frac{1}{2}MR^2\alpha
{\omega }_z=0\alpha =\ \frac{{\omega }_{0z}}{{\mu }_kt}
\tau =-\frac{1}{2}Mr^2\frac{{\omega }_{0z}}{{\mu }_kt}
\tau =r\times F
r\times F=\frac{1}{2}Mr^2\frac{{\omega }_{0z}}{{\mu }_kt}
{\mu }_k=\frac{Mr{\omega }_{0z}}{2tF}
F=f{\mu }_k
{\mu }_k=\frac{Mr{\omega }_{0z}}{2tf{\mu }_k}
{\mu }^2_k=\frac{Mr{\omega }_{0z}}{2tf}
{\mu }_k=\sqrt{\frac{Mr{\omega }_{0z}}{2tf}}
Okay, although not provided in the question, I am assuming that you are supposed to find coefficient of kintic friction. (Your attempt at the solution tells me that.)
You erred in this statement:
zbobet2012 said:
\tau =r\times F
Note that, torque produced by F is not the one which is producing deceleration in the disc (It is in a perpendicular direction to ωz!), rather it is f, torque due to friction which is producing deceleration. Keep this in mind and I hope you would be able to solve it, as you know other things, it seems.
F=f{\mu }_k <---isn't that the force due to friction? Or am I confused? Realizing I kind of messed up my notation, f = 170N and F_{friction}=F
