Troubleshooting a Torque Driver Assembly
A user disassembled a torque driver assembly and is unable to achieve the click sound during calibration after reassembly. The primary suggestion is that the assembly may have been incorrectly reassembled, potentially leaving out parts. Participants emphasize the importance of ensuring all components are correctly placed and accounted for. Troubleshooting tips focus on reviewing the assembly process step-by-step. Proper reassembly is crucial for the torque driver to function correctly.
stan
hi all,
i did a dissambley of a torque driver, and when i put it back, i could not get teh click sound when i tried to calibrated the wrench..
any idea wat is wrong?
regards,
ss
You probably put it back together wrong...
Are there parts left on the table?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
