Is the Calculated Torque on a Bolted Beam Correct?
  • Thread starter Thread starter vbplaya
    Beam Torque
The discussion revolves around calculating the torque on a bolted beam with a 500 kg steel beam and a 70 kg worker standing at its end. The torque is calculated using the formula t = r x F, where the forces include the weight of the beam and the worker. The user arrived at a torque value of 12,544 N m. Other participants confirm that the calculation appears correct. The overall consensus is that the user's approach and result are valid.
vbplaya
hey could someone please help me to check if i did this correctly and got the right answer please? thanks
A 4m long, 500kg steel beam extends horizontally from the point where it is bolted to the framework of a building. a 70 kg construction worker stands at the far end of the beam. what is the magnitude of the torque about the point where the beam is bolted?
i used t=r x F
2(500)(9.8) + 4(70)(9.8)
my result came out to be 12,544 N m...
i am not sure if this is correct or not. thanks.
Looks good to me.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
