Torque on a loop of wire carrying a current
To calculate the maximum torque on a square loop of wire carrying a current, the area of the loop is needed, which can be derived from the wire's length. The wire's total length is 0.477 m, allowing the determination of the side length of the square. The torque formula used is t = NIABsin(θ), where N is the number of turns, I is the current, A is the area, and B is the magnetic field strength. In this case, with one turn (N=1), the calculated torque is 0.023 N*m, indicating a possible error in the area calculation. Accurate area measurement is crucial for correct torque computation.
figs
A 0.477 m length of wire is formed into a single-turn, square loop in which there is a current of 13.5 A. The loop is placed in a magnetic field of 0.124 T, as shown in the figure below. What is the maximum torque that the loop can experience?
if i had the area i could figure it out
But you know it's a square and you have its circumference!
YOu can figure out what is the length of the sides of the square from the given information.
how am i to fig out N? t=NIABsin90
N is the number of turns.
that's wut i thought
t=(1)(13.5A)(0.014m2)(0.124)(sin90)
t=0.023 N*m
i did something wrong somewhere
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
