How Do Flywheels Store and Deliver Energy Efficiently?
Flywheels are effective energy storage devices that can release energy quickly after being spun up slowly. In this discussion, a problem involving a flywheel with a diameter of 2.0 m and a mass of 270 kg is analyzed, focusing on its energy storage and delivery capabilities. Key calculations include determining the time to reach maximum speed, the energy stored, average power delivered to a machine, and the torque exerted. The user initially struggles with unit conversions and rotational kinetic energy calculations but eventually finds correct values for energy and power. The discussion highlights the importance of accurate unit conversion and understanding rotational dynamics in solving physics problems.
kikko
Flywheels are large, massive wheels used to store energy. They can be spun up slowly, then the wheel's energy can be released quickly to accomplish a task that demands high power. An industrial flywheel has a 2.0 m diameter and a mass of 270 kg. Its maximum angular velocity is 1500 rpm.
A) A motor spins up the flywheel with a constant torque of 58 N\cdot m. How long does it take the flywheel to reach top speed?
B) How much energy is stored in the flywheel?
C) The flywheel is disconnected from the motor and connected to a machine to which it will deliver energy. Half the energy stored in the flywheel is delivered in 2.2 s. What is the average power delivered to the machine?
D) How much torque does the flywheel exert on the machine?
T = r x F
a = Tnet/I
I = \Sigmamr^2
Krot = .5Iw^2
Period = 2pi/w
I=.5MR^2
I first apologize for the lack of units, I'm not very solid with units while doing rotational work and get confused as to what they should be.
I = .5(270)(2)^2 = 540kg*m^2
1500rpm = 2pi/w = 25 rounds/seconds
w = 39.59
a = (58/540) = .107 (theta)/s^2
Actually, I just solved the first part when typing that out at 370s. The rest of the problems seem pretty linear, but I can't figure them out. I'm just plugging it into the Krot=.5Iw^2 forumla, and the answer comes out wrong.
I've tried this problem for a couple hours and asked tenish people from my physics class how to do it, but they couldn't figure it out either.
w = 39.59
ω should be in rad/s (radians per second)
and α would be in rad/s2 (radians per second squared)
This is just asking for the rotational kinetic energy.
Power is simply energy/time
Another way to write power for rotational motion is P=Tω
So it looks like if I can get part B done then I can get the rest by just using that answer.
I'm doing Krot=.5Iw^2=(.5)(540)(39.69)^2=425000, but this is comming out wrong in Mastering Physics. I've tried 425329 and some others, and now am down to 1 more guess. Any help?
Sorry, I forgot to point out your error. You converted 1500 rpm incorrectly.
rpm means revolution per minute
1 revolution = 2π radians
1 min = 60 seconds
Hence 1 rpm = 2π/60 rad/s
so 1500rpm = 1500(2π/60) rad/s
Okay, i got 1.7*10^6 for B which is correct, and 3.8*10^5 for C, which is also correct.
For D, I'm doing 3.8*10^5 = Tω
(3.8*10^5)/w = T
I'm not sure how to get w. I do not believe it is my original ω, because using ω = 25*2pi gave me the wrong answer when use as (3.8*10^5)/(25*2pi). I'm not sure how to come up with the new ω to get the new T.
It would be the same angular velocity with half of the power.
