Total energy of an airplane, work done against air resistance
The discussion focuses on calculating the work done against air resistance for an airliner during its climb to cruising altitude. The user initially applies the energy conservation equation but arrives at an incorrect result of 3.58 x 10^10 J instead of the expected 3.83 x 10^9 J. They reevaluate their approach, suggesting that the equation should be rearranged to properly account for the work done against air resistance. The user also notes the importance of the relationship between energy, power, and time in their calculations. The thread emphasizes the need for careful application of physics principles to solve the problem accurately.
furor celtica
An airliner of mass 300 tonnes is powered by four engines, each developing 15 000 kW. Its speed at take-off is 75 m(s^1), and it takes 11 minutes to reach its cruising speed of 210 m(s^1) at a height of 10 000 metres. Calculate the work done against air resistance during the climb.
Alright so I have reasoned that (total energy at take-off)+(work done by engines)+(W, work done against air resistance)=(total energy at 10 000 metres) and that:
Total energy at take-off = PE +KE = 0 + (0.5 x 300 000 x (75^2))
Work done by engines (in 11 minutes) = (60 000 000)/(660)
Total energy at 10 000 metres = PE + KE = (10 000 x 300 000g) + (0.5 x 300 000 x (210^2))
G=10
Which makes W (work done against air resistance) = ((10 000 x 300 000 x 10) + (0.5 x 300 000 x ((210^2)) – (0.5 x 300 000 x (75^2)) – ((60 000 000)/(660))) = 3.58 x (10^10) J correct to 3 s.f.
However, the correct answer is 3.83 x (10^9) J.
What mistake(s) did I make?
I think that the above equation must be
(total energy at take-off)+(work done by engines) = (W, work done against air resistance) + (total energy at 10 000 metres)
Note that Energy = Power x time
thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
