Hi flyingpig,
flyingpig said:
I am confused, what do you mean by the equilibrium position? Do you mean the spring's equilibrium position?
I don't think it was at the spring's equilibrium point.
The equilibrium position is the position at which the forces on the mass are balanced (zero net force). In the case of a horizontal spring, since no forces are present other than the spring's restoring force, equilibrium occurs when the spring is neither stretched nor compressed, and hence the restoring force is zero.
In the case of a vertical spring, you also have gravity. So,
it's no longer true that equilibrium occurs when the spring is at its normal length. Instead, equilibrium occurs when the spring is
stretched sufficiently that the upward restoring force balances the weight of the suspended mass. Your problem calls this equilibrium point the
stretched equilibrium position to emphasize that equilibrium occurs when the spring is stretched (unlike in the horizontal case). It is this stretched equilibrium point that PeterO was referring to as the initial position.
flyingpig said:
So I still have
mg = ky
mg/k = y
E_i = \frac{1}{2}ky^2 + mgh
E_f = \frac{1}{2}ky'^2 + mgh_f
\Delta E = mg\Delta h + \frac{k}{2}(y'^2 - y^2) = 0.25*9.8*(15cm) + \frac{k}{2}{15^2 - (\frac{mg}{k})^2}
Everything looks fine except the difference in spring extensions. Initially, the spring is extended to a length of y = 5.1 cm beyond the unstretched length. (you worked this out). But then it gets pushed upward by 15 cm, which means the new length must be y' = 5.1 - 15 = -9.9. So the spring becomes 9.9 cm shorter than its unstretched length. These displacements y and y' are what you enter into the elastic potential energy terms.
EDIT: the 5.1 becomes exactly 5.0 if you use g = 9.8, as PeterO pointed out.
