A Total force generated in a pneumatic cylinder-piston with kn
The discussion focuses on modeling the total steady-state force on a pneumatic cylinder-piston system, factoring in leakage. The desired equation is in the form of F=f(P1, A, L, c), with extreme cases highlighting hydrostatic pressure when clearance approaches zero and air drag when clearance is large. The relationship between pressures P0 and P1 is critical, especially during transient conditions, where F can be approximated as (P1 - P0) x A. The calculation of P0 at any time t relies on standard air flow methods, while viscous air drag is often negligible in practical scenarios. Understanding these dynamics is essential for accurately predicting the force required to maintain the piston in place.
foadsf
I have also asked this question in SO and CFD online
Assuming that we have a pneumatic cylinder-piston with arbitrary but known surface area A, a known clarence c, and a known length L. What is the best model to describe the total steady state force applied on the piston considering the leakage? (the force required to keep the piston in place)
What I'm looking for is an equation in the form of $F=f\left(P_1,A, L, c\right)$. In extreme cases:
- if ## c\rightarrow 0 ## then ##F=P_1A## is just hydrostatic pressure
- if c is big then ##F\approx \frac{1}{2}\rho\nu^2C_DA## is just air drag
I can calculate leakage from empirical or theoretical models but I don't know how to proceed from there.
Given that the piston is not moving and that there is at least some leakage of air possible around the piston then :
When the system is in steady state condition P0 = P1 and F = 0
When the system is in transient condition P0 is initially < P1 but increases with time as air flows around the piston . To a good approximation at any time t during this transient period F = (P1 - P0 at time t) x A .
The value of P0 at time t can be determined using standard air flow calculation methods .
You could calculate the viscous air drag force on the piston at time t as well but it is likely to be insignificant in many practical cases .
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
