Line Image Transformation with 3x3 Matrix - Vector Solution
  • Thread starter Thread starter takercena
    Transformation
The discussion focuses on finding the image of the line defined by r = i - j + n(i + j + k) under a specified 3x3 matrix transformation. The transformation is applied by multiplying the matrix by the vector representation of the line, leading to confusion about the parameter n and its role in the transformation. Clarification is provided that the image of a vector x is obtained by the matrix multiplication Mx, while the inverse matrix is used to find an inverse image x such that Mx = y. Participants express uncertainty about when to use the inverse matrix in the context of transformations. Understanding these concepts is essential for correctly applying matrix transformations in vector form.
takercena
Please help me solve this question:
Question: Find the images of the lines r = i - j + n(i + j + k) under transformation
M (matrix 3 x 3) =
(2 1 4)
(3 5 1)
(1 2 0)
in vector form.
The image under the transformation is just that matrix times the vector? But what is n? My first thought was that it was the parameter but then that is just a single line. If that is correct then r= i- j+ n(i+ j+ k)= (n+1)i+ (n-1)j+ nk and its image is
\left[\begin{array}{ccc}2 & 1 & 4 \\ 3 & 5 & 1 \\ 1 & 2 & 0\end{array}\right]\left[\begin{array}{c} n+1 \\ n-1 \\ n\end{array}\right]
Thank you. There is some confusion here. I am confuse when to use inverse matrix to find transformation. Can you explain this. Example : 1. Find the images under the transformation
I have no idea what you mean by that. You use the inverse matrix in order to find an "inverse image": x such that Mx= y. Given a matrix M, the image of x is, by definition Mx.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
