Transformer Efficiency: Why Does Direct Loading Not Determine It?
  • Thread starter Thread starter glasgowkizz
    Transformer
The discussion centers on the efficiency of transformers and why it is not solely determined by direct loading. It highlights that a transformer with high efficiency, such as 99%, can produce misleading efficiency readings due to small errors in voltage or current measurements. Participants suggest that these questions are more appropriate for homework help forums rather than engineering discussions. The conversation emphasizes the importance of providing relevant equations and attempts at solutions when seeking help with schoolwork. Ultimately, the thread is redirected to a more suitable forum for academic inquiries.
glasgowkizz
Why is the efficiency of a transformer not determined by direct loading?
Could you please clarify the question? Also, where are these transformer questions coming from? Are you reading a textbook or online resource about transformers?
Probably because large transformers are too efficient.
If a transformer is 99% efficient then an errow of 1.1% in reading primary or secondary volts or amps could give you an efficiency greater than 100%.
Our professor gave these questions as an assignment.
Thanks for your opinion.
Then these questions belong in the Homework Help forums, either in Intro Physics or Engineering. Please do not post schoolwork questions here in the EE forum.
And you need to post the Relevant Equations and your Attempt at a Solution when posting schoolwork questions here on the PF.
I'll move this thread now, leaving an expiring redirect behind in EE.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
